car running really rich
Old Nov 17, 2009 | 01:51 PM
agentwind's Avatar
i think my car is running really rich. the exhaust sound is VERY deep and the car feels like its towing something(very sluggish)
this first started a few weeks ago when i was leaving work and i gave it on a curve(not hard, just enough to make the drive fun)
while giving it the CEL came on flashing, after a few sec of flashing it turned off.
after that the car was running sluggish
also since then if i rev it past like 6 or 7k the CEL light will flash
also a couple days after the first occurrence(and a few times since) the CEL actually stayed on solid but went away after the 3 power cycles
now from reading up on the forums here i believe the flashing CEL means misfire and i confirmed this with an engine code reader
i have purchased new spark plugs, ignition coils and plugs
i have also been looking into an o2 sensor (because of the engine running rich even with the CEL off)
any thoughts or similar incidents?
also is 155 miles(250km) to 13.2gal (50L) standard?
Old Nov 17, 2009 | 01:54 PM
Jon316G's Avatar
Grasshopper
Clogged cat?
Old Nov 17, 2009 | 02:18 PM
agentwind's Avatar
Originally Posted by Jon316G
Clogged cat?
that was actually what i was thinking as well
how could i check for that?
Old Nov 18, 2009 | 05:32 PM
04RX8man's Avatar
Rotary Powered Countryboy
did u change ur coils/plugs?
checking the cat is as easy as removing it and looking inside
Old Nov 19, 2009 | 07:38 AM
agentwind's Avatar
i havent checked my coils and plugs but i have purchased new ones anyways
the car has 100,000km(60,000miles) on it and I bought it a year ago with 80,000km(50,000miles)
im not sure when(if ever) they were changed before
Old Nov 19, 2009 | 07:47 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
155 miles is pretty low, I will get 240 miles before my light comes on.
Change those plugs, coils, and wires.........immediately then possibly you can move on to the CAT and possible o2 sensor if that doesn't solve it. If you keep running it as it, IMHO.............you will take out the CAT in short order even if it's okay now.
Old Nov 20, 2009 | 02:35 PM
corners's Avatar
An RX ate my baby
If your cat isn't bad now, if you continue to drive it that way it will be. Try coils and plugs first.
Old Nov 20, 2009 | 07:02 PM
04RX8man's Avatar
^yes agree with the 2 above posts....keep dumping raw fuel into the cat and it will b gone before you know it....
cushing75
Nov 12, 2018 12:46 PM
9krpmrx8
Nov 5, 2015 11:45 PM
ShadowGryphon
Jul 29, 2015 05:40 PM
Bamaham
Jul 23, 2015 08:08 AM
yapakanichi
Jul 20, 2015 02:17 PM
