coolant..
Old Nov 17, 2009 | 01:22 PM
RX8prs's Avatar
coolant..
just wondering what kind of coolant or mixes are people using and any results in running cooler
Old Nov 17, 2009 | 01:35 PM
StealthTL's Avatar
Up here, we use 60/40 or even 70/30 strength, but that is for freeze protection, and would be lousy for a hot climate.
In theory, the more water/less glycol you run, the better it cools, but in pratice your engine would soon be a rusty corroded shell on just water. That's why it's called 'coolant' not 'antifreeze'.
Good coolant has lube for the waterpump, amines for pH buffering, and silicates or similar for aluminum protection. The layout of the wankel is a recipe for a fine electric cell, given the right electrolyte - (aluminum) water pump on front (steel) plate, front (aluminum) housing, midplate (steel) etc., you get my drift.
More than 50% water is asking for trouble if you don't change the whole volume out every couple of months......
S
Old Nov 18, 2009 | 05:02 PM
04RX8man's Avatar
Rotary Powered Countryboy
i use 50/50....but have heard on here some ppl using 100%water with a whole bottle of water wetter...but ipersonally have no experience with that
Old Nov 18, 2009 | 05:17 PM
chino0314's Avatar
ive read water wetter is bad.....
Old Nov 20, 2009 | 01:55 PM
UrbanOcho's Avatar
Stick Specialist
...but it's still better than a bed wetter!!!
hahahahaha
Old Nov 20, 2009 | 01:59 PM
Huey52's Avatar
Registered Zoom Zoomer
50/50 pre-mixed GMC Dexron myself and no longer a bed wetter, I mean no longer use water wetter.
edit: hhhmmm... I just remembered that I now [thanks to BHR] have GMC Yukon coils as well. I'll turn my '8 into a truck yet!!!
Old Nov 20, 2009 | 03:49 PM
Nubo's Avatar
Lubricious
50/50 for my 2004. It never gets much below freezing here.
IIRC, newer RX-8 use some specialized coolant, so stick with that.
Old Nov 22, 2009 | 11:20 PM
It all depends upon the weather in the area where you live...........
Old Nov 29, 2009 | 05:22 PM
RX8prs's Avatar
i live in cali near la
Sturmgezhutz
May 27, 2012 08:54 AM
alz0rz
RX-8 Multimedia/Photo Gallery
22
Jun 2, 2008 12:33 PM
