Supercharger ???'s
Old Nov 9, 2009 | 11:59 AM
ilovemy8's Avatar
Supercharger ???'s
i have utliized the search button b4 all you throat swimmers jump down my throat and drown..
and i cant find info on whats needed for aadding a supercharger to the 8
like in a turbo you need the intercooler and the fuel injector upgrade and the piping the BOV, etc etc...
what all do you need for superchargering?? is it just a bolt on action?
in a preference i would be referring to the pettit..
Old Nov 9, 2009 | 12:01 PM
mscamp02's Avatar
Blue Bullet?
obviously you didnt really search worth anything....your best bet is to just go to pettits website and look at the kit...to simple and to easy
Old Nov 9, 2009 | 12:13 PM
ilovemy8's Avatar
im really glad you came and replyed.. because your right.. expecially sitting right next to me on my search adventure..
well it seems as if the kit is all you need.. until a higher than recommmended psi is applied...
Old Nov 9, 2009 | 12:23 PM
mscamp02's Avatar
Blue Bullet?
so now your demanding me to go look for you because you failed???
when you buy the kit its everything you need....all the info is on the site, I know I have checked before. there is a thread called pettit supercharger owners....that may be a good place to look but im guessing you didnt....
Old Nov 9, 2009 | 12:29 PM
Highway8's Avatar
Registered RX8 Nut
YOU go to the website and locate what im asking for becuase i couldnt..
The answer all depends on what your power goal is. If you are going to stay under 280-300 HP you can probably get away without an injector upgrade.
Simple bolt on? If you buy a kit designed for the RX8 then yes it is all just bolt on and a kit will include the supercharger, brackets, belts, pulleys, an intake kit with maf housing and air filter, intercooler piping and couplers (for the hymee and DNA kit) heat exchanger and hoses (for the pettit kit) along with a veriety of other little parts. plus any kit is going to require tunning.
Hope that helps a little. Now on a more serious note, you do need to do some more FI research. There are numerous different types of supercharger systems, only a few for the rx8, Pettit, hymee and DNA, maybe a couple more. Pettit has the most customers, the DNA kit never really made it to the USA but has been around for a long time and the hymee kit has several in the USA and more to come. Each kit has its pros and cons and they are all use a different style of supercharger. The kit that is best for you will greatly depend on what your goals are. Depending on that answer, a turbo may be better for you or maybe no FI at all.
Good luck.
Old Nov 9, 2009 | 12:34 PM
maxxdamigz's Avatar
Baro Rex
Answering this question will not help you because there is tons of information you should know before FIing the car.
Some tidbits:
1. You do not need injectors. This "need" is determined from fuel demand. The stock fuel injectors are good until X whp. Exceed X, replace injectors.
2. You do not need BOV piping in a turbo setup. It'll help you some in a MAF system but even then it's not a need persay.
3. You do not need an intercooler at low boost values.
4. Pettitt may not be making kits for a while but if they are making a list of people for another batch, call them and get on it. Then have them tell you what you need. From reading their site, you need the kit + management.
A supercharger and a turbocharger are basically the same thing done two different ways.
Old Nov 9, 2009 | 12:36 PM
ilovemy8's Avatar
thanks for the info greatly appreciated.. and i wasnt demanding.. i was being a jerk as i felt you were too..
i will be fine at 300 it will be more than enough.. and with my other upgrades i think that a cobb AP(as well) will put me up a bit over the 300 mark
i thought about a turbo and was going to but.. the thing i like about the SC is the boost at full rpm range rather than a limited range due to charging up boost..
and it did seem as if the SC in the long run would be less cost comsuming..
also there is a video of the 8 with the pettit SC and it sounds sexy
mscamp02's Avatar
Blue Bullet?
^ From my understanding when you buy pettits kit they send you something to track your cars ECU for a while before sending you the kit and pettit does all of the tuning for you
Old Nov 9, 2009 | 12:39 PM
mscamp02's Avatar
Blue Bullet?
less cost consuming no...it just seems that the supercharger kits are better built however both super and turbo set ups lessen the life of the engine. Also the two SC kits out cost more than any turbo kit out
Old Nov 9, 2009 | 12:46 PM
ilovemy8's Avatar
^ is true as far as the kits concerned..
to my understanding.. turbo charging will be a bit more than sc due to the installation. it will also need a proper tune upon install correct??
a SC seems more DIY friendly..
but im not positive.. the pettit kit was 5k n some changes
but when you buy a kit for a TC+ installation and tuning wouldnt it be very close in price?? for example the greddy turbo kit is like 3.6k i mean it probably wouldnt be another 1400 in install cost but than again.. idk
plus the whole full rpm range is better IMO!!
Old Nov 9, 2009 | 12:52 PM
mscamp02's Avatar
Blue Bullet?
I to am for superchargers over turbo however installing will probably cost you about the same either way if you do not wish to do so yourself. pettit offers a 1k install on their kit at their shop in florida.
Old Nov 9, 2009 | 01:19 PM
ilovemy8's Avatar
i was gonna do the install myself.. with help of coarse but it would be easier than the tc i believe
Old Nov 9, 2009 | 02:03 PM
tubingchamp's Avatar
What mawd bug?
Yea, from a DIY standpoint it's easier. The hymee kit you don't even need to drill anything (except one tiny hole afaik). Tuning is the same story with a turbo. NEEDED.
Old Nov 9, 2009 | 02:08 PM
ilovemy8's Avatar
his is the same amount of price isnt it???
how much HP did he get out of his??
Old Nov 9, 2009 | 02:12 PM
What mawd bug?
It's about fit and finish, and quality. The power levels are nearly the same, but the Hymee kit is more expensive. I'll get the first one in North America, but there has not been a wheel dyno. If I was looking for huge numbers, I'd go turbo, but I'd rather have the best kit available then have the largest e-peen anyways.
Hymee has a larger blower, and I think it would hold together better in the long run than a pettit. That being said, I don't think we've had an engine failure due to S/C yet. Olddragger blew his motor with a pettit kit, but I think there was another underlying problem, don't remember.
I seriously think you need to read up the Pettit and the Hymee threads and compare which is more important for you. Knowledge is power.
Old Nov 9, 2009 | 02:14 PM
mscamp02's Avatar
Blue Bullet?
the Hymee is more...its 7500 or something like that and runs on the same exact setup as the pettit kit. It does though come with Hymees excellent tuning software so you wont need to purchase something else
Old Nov 9, 2009 | 02:18 PM
What mawd bug?
The bolded is totally wrong.
Check the Hymee thread. Every part is diff, from the custom giant FMIC, to the 2.1 liter blower, to the custom fabbed italian-cut gears, etc etc.
Old Nov 9, 2009 | 02:27 PM
RIWWP's Avatar
With the dropping value of the dollar vs other currency, you have to pony up close to $10k to convert it to enough Australian dollars to buy the Hymee kit now.
I would also be careful of throwing around the power band arguement. Quite a few people on here will disagree with you, including me. Turbo's need to spool up, true, but any properly sized turbo for the power you want will be fully spooled by 3k rpm, and you don't even cruise down that low.
The Hymee kit is my #1 FI choice if I ever get the money. I prefer the NA feeling over the kick in the pants.
Old Nov 9, 2009 | 02:30 PM
What mawd bug?
I hear there's still quite the kick in the pants, it just feels more natural
Old Nov 9, 2009 | 02:31 PM
mscamp02's Avatar
Blue Bullet?
Damn I thought I read somewhere on here that the hymee kit was essentially on the same setup as the pettit so you will get essentially the same hp gains....guess I was wrong oh well lol
Old Nov 9, 2009 | 02:33 PM
RIWWP's Avatar
Like the midget in your seat aiming with his steel toed boot is supposed to be there?
Old Nov 9, 2009 | 02:38 PM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
I'm subscribing just so I can get a few laughs
Old Nov 9, 2009 | 02:44 PM
What mawd bug?
This made me confused
Old Nov 9, 2009 | 05:59 PM
Wind Dance's Avatar
Central Valley RX8
This thread will be another Funny one..
Old Nov 9, 2009 | 06:24 PM
mscamp02's Avatar
Blue Bullet?
^Will be....I'm having a great time lol
