Series II Technical and Trouble shooting Discuss technical details for the Series II RX-8 and any issues or problems you are facing
2009 RX8 R3 won't rev past 8k
Old Nov 2, 2009 | 06:25 PM
discomonkey's Avatar
Ok I just bought a 2009 rx8 r3. I know it's not the best idea put I wanted to see what it could do really quick so I decided to wined it out. What I noticed is that once I hit 7k it hasitates and It won't rev past like 8k or so. What could this be?
Old Nov 2, 2009 | 06:28 PM
gregs's Avatar
Pull My Finger
are you trying this with the engine cold?
Old Nov 2, 2009 | 06:29 PM
is the engine fully warmed up?
don't the new ones have the 'moving redline'?
Old Nov 2, 2009 | 06:33 PM
No, warm engine
Old Nov 2, 2009 | 06:35 PM
how 'warm'
It's not going past 8k after driving the car around for 15 minutes plus?. what gear are you trying to do this in?
you mention it's 'hesitating', can you be more descriptive?
is there a CEL on?
do you see anything blinking on your dash as you're trying this?
Old Nov 2, 2009 | 06:36 PM
Yes they do but once they are warmed up the redline is at normal.
Old Nov 2, 2009 | 06:40 PM
chris__n's Avatar
should you even be doing that on a brand new car?
how 'warm'
is there a CEL on?
I haven't seen any cel or blinking. How warm is about 10 mins of warn up time and 15plus of drive time. Hesitating like there is no power at all
Old Nov 2, 2009 | 06:43 PM
could be a few different issues but seeing as how it's an '09 it's a bit puzzling
Your car is probably misfiring due to something wrong in the ignition system; coils, wires, or plugs
Your cat could be clogged
I'm leaning towards ignition.
Ever flooded the car?
how many miles are on it?
Old Nov 2, 2009 | 06:56 PM
Symbioticgenius's Avatar
You Dumbass!!!
^+1
Cause he didn't state the car was New.
Old Nov 2, 2009 | 07:10 PM
Originally Posted by Symbioticgenius
^+1
Its new 300 miles on it and I know I shouldn't be doing it
Old Nov 2, 2009 | 07:13 PM
Grungepup's Avatar
Oilfield trash
ummm its because the car wont let you go above 7k .... it has a "break in" period up to 5000 miles
Old Nov 2, 2009 | 07:16 PM
I8U's Avatar
I8U
How about break the engine in properly and get back with us then.
Old Nov 2, 2009 | 07:28 PM
Question
Sorry. Sounds like a plan. Thanks
Old Nov 2, 2009 | 09:10 PM
what?
no it doesn't.
why?
The car SHOULD be able to go to redline the minute it rolls off the assembly line. Break-in shouldn't have anything to do with this.
I still say something is wrong.
Old Nov 2, 2009 | 09:24 PM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
^+1 on what Jedi said. I bought my car with 92 miles on it. As soon as I took it for a test drive I revd to 7k in my auto during the test drive but I didn't push it. Only once did I redline. The break in period is about 600 miles or so not 5000. Taught the dealer some important info on our cars.
Question also important how often does he drive/start his car??
Old Nov 2, 2009 | 10:26 PM
I8U's Avatar
I8U
Some of you are forgetting it is an '09 this guy is talking about. A lot has changed with the ECU programming...I believe Mazda finally got smart and tweeked the system so the new motor can't be f'd up right out of the gate.
Old Nov 2, 2009 | 10:28 PM
I'm not forgetting it's an '09, but I haven't read that anywhere, have you?
The ECU programming refers only to temperature on the '09's, not mileage.
Old Nov 2, 2009 | 10:37 PM
gregs's Avatar
Pull My Finger
i have driven a few 09's with no issues of redlining one was a r3 model with 50 miles on it
Old Nov 2, 2009 | 11:32 PM
plain ole wanker's Avatar
wankel my wanker
Didn't know better at the time but I couldn't help it had to try it redline mine 9k no problem before break-in '09 smooth with beep. It's obvious I'm no expert but this sounds fishy to me.
Old Nov 2, 2009 | 11:45 PM
RX8pwnage's Avatar
RX8. Yeah, I get it.
It will rev 9k right off the lot. Trust me. Something is wrong with your car.
Old Nov 3, 2009 | 12:20 AM
Still retarded to do it. I just hope you haven't been doing anything stupid because the dealer will see whats up. But definitely take it in.
Old Nov 3, 2009 | 12:46 AM
You Dumbass!!!
Yeah, the replies here are insane. I say wait till 2000 miles, if it still wont redline go to a mazda dealer and tell them this VERBATIM.
Hi, I finished my break in period, and was trying to get to 9k RPM's and my car hesitates at around 7.5-8k. This is not normal, I think something is wrong, could you check it out please. Thank You.
If you tell them you've been redlining during break-in they will use it as an reason to void your warranty, and I will use it as an reason to laugh my *** off. Good luck.
Old Nov 3, 2009 | 06:36 AM
RX8pwnage's Avatar
The point of this thread isnt if he is retarded or not, its what is wrong with the car.
What IS retarded is saying that after the break in period it will magically hit 9k rpm. No.
I test drove three 09s at dealerships and guess what? Every one of them went to 9k and one even had MIAC, ha!
Should you be redlining yet? No. Should it hit 9k? Yes. Is something wrong with the car? Yes.
Old Nov 3, 2009 | 06:45 AM
Huey52's Avatar
Registered Zoom Zoomer
Definitiely something wrong. As the more insightful here cite the vehicle is capable of hitting the redline right off the assembly line.
I believe in proper break in periods, but we all know that someone probably test drove our new vehicles before we bought them and wound it out to redline, perhaps even a salesman.
Take it back for in-warranty diagnosis and resolution - simple.
