OBX headers........again :)
Old Oct 26, 2009 | 08:52 PM
rx8montreal's Avatar
hello everyone! first of all i'll say i have read all treads concerning these headers(obx)
i need some pros here please, i am concerned about the possible cel that would come out from ecu and about that o2 bung placement! i had these headers from a friend and they are not installed yet! i'm not planning of getting any gains but i need to know for sure if i can put them on my car and not to worry about throwing a cel to my car of having issues with A/F ratio cause of the bung placement!
so my question is simple, can i install these headers and not have any problems?
Old Oct 26, 2009 | 08:53 PM
i only have now in my basement exotic speed r1-t exhaust and mazdaspeed cai!
i'm planning on buying COBB accessport from mazdamaniac.com
Old Oct 27, 2009 | 07:33 AM
michaelsk8er's Avatar
Installing this should not cause any CEL unless you mess up the O2 sensor. I installed a BB header and even with an exhaust leak I don't have a CEL. You will have to reset the management (tap the brake 20 times till the oil meter sweeps) so the computer can adapt to the increased air flow. My car idled like crap till I did that and then it straightened right back out.
Other than that it is a pin to install and you'll probably have fitment issues with the CAT, like I did. The header will fit nicely, it is just hard to get it in that little area at first. I jacked the engine up a couple notches.
Old Oct 27, 2009 | 12:04 PM
lepichichi's Avatar
I LuV mY Rotary....
I had mines for over a year with no cells or problems at all, i also didnt notice any hp and they are way lighter thank stock
Old Oct 27, 2009 | 08:40 PM
what is the factory air tube for? why isnt there on obx headers? can i modify it to install it?
Old Oct 30, 2009 | 12:44 PM
can someone tell me what will it cause not to install the air tube on it???
Old Oct 30, 2009 | 01:24 PM
Are you talking about the EGR(Exhaust Gas Recirculation) tube?
What factory air tube are you referring tube?
Old Oct 30, 2009 | 04:04 PM
ell on my obx headers theres is a place to hooked up a tube of some sort! but its seems that they made the headers so hat whatever would connect to it wouldnt work!
Old Oct 30, 2009 | 04:09 PM
shazy's Avatar
/\ Hey welcome
Im from montreal too. I guess they are ok, they say that the car has little bit more down low.
RX7.9
Jul 20, 2015 12:01 PM
Jabberwock
541
Apr 9, 2015 10:19 AM
supergoat
185
Dec 29, 2014 11:49 AM
Schoonie3
13
Aug 12, 2006 02:13 PM
