Rubber Isolator
Old Oct 24, 2009 | 08:04 PM
bhop's Avatar
NO A/C :(
Rubber Isolator
Tein Basic Coilover:
I have a bit of a fish tail type of feel when driving from the rear obviously.
  • Could not having a "rubber isolator"(springs sit on etc) cause this type of movement?
  • Could my swaybars and or end-links be the issue?
  • What about control arms/rods?
  • Has anyone else dealt with this issue before?
Thanks for any sort of advice
-Brandon
Old Oct 25, 2009 | 12:25 AM
Talic's Avatar
check your tire pressure (low pressure creates the same feeling)
inspect everything is fastened properly (play in control arms or shock mounts)
check the 4 wheel alignment via laser (probibly not driving stright giving the fishtail feeling)
the swaybars and isolator are most likely not the problem
Old Oct 25, 2009 | 12:39 AM
Lord ET's Avatar
Is that a bike rack?
pew pew pew
Old Oct 25, 2009 | 10:09 AM
bhop's Avatar
NO A/C :(
Tire pressure has not been checked for sometime now, so I will check it. I'll get it on a lift and check all suspension components. I got a 4 wheel alignment back in August but I guess I'll go or another one or at least check on the machine's computer to see if it's really that bad. I figured that you did not need the rubber isolator but wanted to make sure but was later told otherwise lol. I don't think its my sway bars either because when I installed them, they were then inspected by tons of people lol. Thanks for the advice.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Rote8
Sep 22, 2015 03:43 PM
RA32425
10
Sep 8, 2015 08:53 AM
Aston177
Sep 3, 2015 11:07 PM
poppinparker
Aug 10, 2015 09:20 AM
