Water in my Tail lights
Old Oct 21, 2009 | 11:02 AM
bkkkk93's Avatar
lately i noticed i have alot of water in my passenger taillight how do i get it out easily?
Old Oct 21, 2009 | 11:17 AM
StormyWankel's Avatar
EVOLVChicago.org
By searching
Old Oct 21, 2009 | 11:59 AM
Socket7's Avatar
ಠ_ಠ
Pull the tail light out, let it dry completely then replace the gasket behind it. Re-install the tail light and all your problems will be gone. There are several DIY's on this here.
Or you could go about things the redneck way and drill drainage holes in your light, and hope that the inside of your tail lights never get hazy from exposure to the elements.
Old Oct 21, 2009 | 12:02 PM
Socket's advice is dead on.
I would not drill holes if it were my car.
if you're under warranty: http://www.finishlineperformance.com....php?pageid=11
P.S. the search function on this site is usually VERY helpful in these situations. (there are already a few dozen threads on this topic)
Old Oct 21, 2009 | 12:03 PM
The Reverend's Avatar
That's a lie
1. Fill tail light with fresh water
2. Acclimate your fish to the new pH balance
3. ???
4. Profit!
Old Oct 21, 2009 | 02:44 PM
nvrfalter's Avatar
tonybob failpants
look at the related threads at the bottom of this page....
Old Oct 22, 2009 | 07:14 PM
ferg's Avatar
why cant you just fill the tail lights with water so you dont have to worry about gaskets maybe get some fish
Old Oct 22, 2009 | 07:24 PM
mscamp02's Avatar
Blue Bullet?
just close this thread now.....close it before the flame and the epic fail
Old Oct 27, 2009 | 10:51 PM
cory_mcm's Avatar
what i did was take the light off and place it over a dehumidifier and let it dry (takes a while)
while it was drying i cleaned the gasket with a old toothbrush (might as well) then i just glued the gasket on with some good adhesive. i think it was called goop. then just reinstall i works well but if you ever want to get the gasket off again i dont think its happening.
Old Oct 28, 2009 | 09:24 AM
dmitrik4's Avatar
please wait for the beep
you can buy the redesigned gasket from Mazda for about $20.
Old Oct 28, 2009 | 11:41 AM
ferg's Avatar
^really?
Old Oct 28, 2009 | 11:43 AM
mscamp02's Avatar
Blue Bullet?
yeah taht would actually be worth it instead of making your own for 10 dollars
Old Oct 28, 2009 | 06:41 PM
pup's Avatar
pup
holla if u hear me
i poured alcohol in mine...........drained it and let it dry.....no water marks.....gl
Old Oct 28, 2009 | 09:12 PM
dmitrik4's Avatar
Originally Posted by ferg
^really?
something like that...might be a little more if you go to the dealer rather than through Mazda Motorsports. either way, it's better than epoxying your taillight to the car.
the part numbers are in the TSB, and you can find that on the finishline site. there is a redesigned gasket and a secondary "pad".
Old Oct 28, 2009 | 09:57 PM
ferg's Avatar
^i went to that site, no luck
Old Oct 28, 2009 | 11:12 PM
fray's Avatar
Where can I get the gaskets for $20?! I went to my local Mazda dealer and they wanted _$40_ each side for the TSB gasket kit! I'd pay $20 for both sides, but $80 is insane...
Old Oct 29, 2009 | 08:31 PM
getdamafiaonyou's Avatar
MAKE YOUR OWN! ive done it 3 times. go buy some tool box drawer liner. pull out your tailight. use the current gasket as a template, cut one out, and lay it over the current gasket. bam, problem solved. 5 dollars, and you can make them for other ppl since you have a whole roll.
Old Oct 29, 2009 | 11:44 PM
prisonerofcs's Avatar
Rxhausted
I used the origional with lots of silicone, ghetto but it works! Just don't be like me and over tighten the screw pulling the stud out of the plastic. It took a machine screw/wingnut/ and epoxy to fix that screw up...
Actually just buy the updated gasket if you can find it for $20.
Old Oct 29, 2009 | 11:46 PM
mike[piston eater]'s Avatar
O' Let's do it.
fail
Old Oct 29, 2009 | 11:55 PM
Good God, another one of these threads? Thanks for the free post
Old Oct 29, 2009 | 11:56 PM
O' Let's do it.
free post ftw
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
erikcamacho15
Sep 12, 2015 11:23 AM
