Anyone use one of these to change their oil?
Old Jan 12, 2004 | 03:16 PM
flatso's Avatar
I'm Tantalizing
http://www.sjdiscounttools.com/mit7200.html
Mityvac
Old Jan 12, 2004 | 03:20 PM
brothervoodoo's Avatar
RainMan is Back
I wonder if that will suck out the remaining HALF of the oil that does not get replaced in a normal oil change?
Old Jan 12, 2004 | 03:21 PM
epitrochoid's Avatar
Riot Controller
on a piston motor anyway, you cant. the tube needs to get to the lowest point of the oil pool, which is of course in the pan. that is unaccessable from the oil filler cap. unless the renisis has a straight shot from the filler cap to the pan, you cant.
youre better off draining the oil anyway, as it allows the crap and garbage to drain out as well.
Old Jan 12, 2004 | 03:36 PM
Sea Ray's Avatar
These actually have a hose you stick down the dip stick tube into the pan, but you will still not get all of it. I use a similar, but 12 volt, type pump on my boat where you can not get under the motors. I guess since we are leaving several quarts in there anyways, whats another 1/2 quart? I will still drain mine, but this pump would come in handy in the event you happen to over fill it.
Old Jan 12, 2004 | 04:19 PM
PUR NRG's Avatar
I posted about a similar device several months ago.
Bottom line: it completely drains oil from some cars (e.g. BMW 540i) and almost completely on others (e.g. Honda S2000). On the RX-8 it will drain 4 quarts, which is what you get through the drain plug.
I also did a study regarding accumulated sludge and found there is no appreciable sludge buildup going through the dipstick.
________
321
Old Jan 12, 2004 | 05:17 PM
flatso's Avatar
I'm Tantalizing
So your saying it just as good as using the plug in the RX-8? Can you qive a link to that post I would like to read it.
Old Jan 12, 2004 | 06:25 PM
PUR NRG's Avatar
Yes it's just as good as using the plug. Have you tried doing a forum search based on my user name?
________
FUTURAMA FORUM
Old Jan 13, 2004 | 11:22 AM
Riot Controller
guess mine didn't come with the small tube. :P all i have is a huge fat hose i use to siphon the water out of the drain pain when my airconditor in my attic freezes :P
Old Jan 13, 2004 | 03:09 PM
i3man's Avatar
Has anyone figured out how to get the other half of the oil out? It's kind of like giving yourself half a bath everyday.
Old Jan 14, 2004 | 02:31 PM
syntrix's Avatar
I like cheese!
Or bathing with yesterday's bath water??
I'd still crack the oil pan bolt unless I epoxied and drilled in a rare earth magnet around the plug to pick up any metal shavings.
Old Jan 14, 2004 | 02:52 PM
neit_jnf's Avatar
I used to put an old speaker magnet on top of the oil filter in my old rotary. What's yur opinion on doing this to newer cars?
Skyl3r
Dec 2, 2019 04:51 PM
Pelleilee
Sep 29, 2019 10:07 AM
uZu
Dec 30, 2015 12:35 PM
motohegg
Aug 23, 2015 08:14 AM
Modern2Strokez
Aug 16, 2015 01:07 AM
