Went back to stock now PROBLEMS!!
Old Oct 19, 2009 | 01:28 PM
camthman's Avatar
So long story short, I took my coilovers off last week and put the stock suspension back on. (including the stock wheels) I get back in the car to take off and the ABS light is on, the the traction control light as well. The never go off. There is a also a loud beep every once in awhile. WTF? I reset the battery and same thing. Any ideas??
-- Cameron
Old Oct 19, 2009 | 02:39 PM
camthman's Avatar
maybe a fuse?
Old Oct 19, 2009 | 02:45 PM
Charlee's Avatar
Retarded User
Did you go over everything and make sure everything was connected? I believe the traction control sensors could have easily been disconnected with the work that you did.
Old Oct 19, 2009 | 02:47 PM
camthman's Avatar
Yeah, I did. I mean I never unplugged anything. I also had the guy check it out on the alignment rack.
Old Oct 19, 2009 | 02:59 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Turn the key to on, but do not start. Turn the wheel all the way to the right and then all the way to the left and then turn the key off.
Then start as normal and remember to not shut it off cold!
Would've thought driving around would've done this reset by itself, but it's worth a try.
Old Oct 19, 2009 | 03:23 PM
camthman's Avatar
I will try this thanks!
Audio Concepts ATL
Sep 26, 2021 01:59 PM
michaelsk8er
Nov 9, 2015 07:06 AM
MarkX
Jul 31, 2015 07:50 AM
Stubbs
Jul 28, 2015 09:23 PM
Belalnabi
Jul 17, 2015 07:48 PM
