AEM CAI error??
Old Oct 17, 2009 | 01:47 PM
JFranco's Avatar
AEM CAI error??
Anyone with AEM getting computer errors?? A guy that works for Mazda told me that the AEM CAI would give me errors in my new 09 R3, he said to wait for the Mazdaspeed one... Is he trying to sell or is this true?
Old Oct 17, 2009 | 01:49 PM
05rex8's Avatar
sold the 8... :(
aem is the same exact intake as mazdaspeed; just rebadged
he is trying to make a sale
you will be fine with the aem
Old Oct 17, 2009 | 01:56 PM
+1 to what 05rex8 said.
AEM = MS, he might or might not know this so he's trying to sell you 'authentic' mazda stuff but you'll be fine with the AEM.
As for the 'computer errors', that's nonsense. (assuming you don't screw up the maf when installing it)
Old Oct 17, 2009 | 02:01 PM
JFranco's Avatar
Thank you guys!!!
Old Oct 17, 2009 | 02:02 PM
that's what we're here for.
Old Oct 17, 2009 | 02:24 PM
ferg's Avatar
just dont drive in a foot of water lol like i did
Old Oct 18, 2009 | 10:45 AM
JFranco's Avatar
NOOOOOO!! That is scary man!
Old Oct 18, 2009 | 11:09 AM
lepichichi's Avatar
I LuV mY Rotary....
^^ hahaha
Old Oct 19, 2009 | 01:17 AM
RX8pwnage's Avatar
RX8. Yeah, I get it.
i have aem on my r3. it caused cel when i first installed it. reset ecu and been fine since.
Old Oct 19, 2009 | 03:38 PM
JFranco's Avatar
Sorry for the noob question... what is cel??
Old Oct 19, 2009 | 04:02 PM
HWK11's Avatar
Lighting Yellow
check engine light
Old Oct 20, 2009 | 12:18 AM
RedRocket8's Avatar
PISTONS are for (|)
The only thing that will cause your 8 problems is damaging the MAF sensor which by the way is REALLLLLLLLLLLLLLLLLY expensive and or if you completely submerge the dry flow filter. That mechanic either doesn't know anything about the AEM intake or he does know what hes doing and is trying to make a sale. Even if you were to get the mazdaspeed intake for the R3 i'm sure you wouldnt buy it from the stealership i mean dealership. I owned the SR Motorsports and the AEM never had a problem. Good luck
Old Oct 25, 2009 | 11:21 AM
adambomb's Avatar
TX
How did you reset your ECU? Why did you need to do that? Is that because of the MAF causing a check-engine-light? I have a 2009 Red R3, and I have been thinking about putting a cold air intake on it, but I am weary of voiding my warranty by not putting on the mazdaspeed cold air intake. I do know the AEM and the MS cold air intakes are 1 in the same for the most part. I did hear they should be coming out with it soon, and I saw a video of a Mazda R3 with mazdaspeed exhaust and CAI.
http://www.carguideweb.com/multimedia/videos/19191/
Also, do you have pictures of your car? I am just curious to see the mods you have done to your R3. I am in Texas as well.
Thanks.
Old Oct 25, 2009 | 08:12 PM
superman28's Avatar
I just installed the aem cai today on my 2009. no lights or problems at all. sounds pretty dam good btw
Old Oct 26, 2009 | 11:21 AM
JFranco's Avatar
As said by a Mazdaspeed mechanic in the stealership (I borrowed that from another forum member...hehehe sounds good), anyway, the AEM and the Mazdaspeed CAI are the same even by the same manufacturer, the difference is that the MS has a mesh in the conduct near the air flow sensor to make it so the sensor does not give out an error, which may or may not occur with the AEM... therefore the same ****! AEM has it available for the 2009 while MS comes out in 2010 spring.
Old Oct 28, 2009 | 08:14 PM
Reason116's Avatar
i live in florida and it sometimes rains pritty heavy... with a CAI would i be fine?
Old Oct 28, 2009 | 08:41 PM
shazy's Avatar
Yeah. As long as the filter get's submerged in a giant bucket of water. Even then, it would have to stay there for awhile.
Old Oct 28, 2009 | 10:10 PM
ferg's Avatar
just dont drive in deep water lol trust me on this one. i say no more then 6ich of water
Old Oct 29, 2009 | 01:13 AM
Thanks.
1. To Reset ECU, 2 ways , one is to unplug your Room fuse for maybe 10 seconds, plug it back, both LTFT and STFT will be gone. if you cant locate the fuse for whatever reason, just go unplug your negative battery terminal for a minute or 2. Plug it back in.
The reason is that, AEM/MS intake has different air volume than Stock intake. This car has a self-learning computer (most car does these days), it builds fuel trim over time. and if you swap the intake, the volume will be different and the computer will be like "wtf?". I mean it will "re-adjust" itself overtime, but the fastest way is to "reset it" and let it "start all over"
2. MS/AEM came form the exact same place. in Japan they dont even offer it as an option, instead, they offer a Mazdaspeed "high flow" filter. Just like they dont offer the Dual Canister MS exhaust in Japan (US people has different taste than Japanese people)
I had MS on my 8 for a year or so. it sounds pretty good. but I went back to stock cuz I want it to be "quiet"
Both can have the Mesh installed. one before and one after the MAF.
The wire mesh is there to straighten/smooth out the airflow to MAF(so it can get correct readings) and to engine (its just trying to avoid "pulse" which might effect idle quality)
Well there is a huge area around my neighborhood that gets flooded everytime it rains hard. I always try to avoid the area cuz the water will go above my exhaust hahaha
Old Oct 29, 2009 | 01:50 AM
Fortunate Few's Avatar
Irollerblade.
the only know computer error that pops up that i know of is the missing mesh plates. If you have those and your filter is dry you are in good shape.
Old Feb 8, 2010 | 04:22 PM
nx04's Avatar
zoom-zoom
i get the flashing cel when im revving high at about 7-8-9k in third it flashes and stays on for a while but goes away not sure whats wrong checked maf with the diy in the forum everything is looking nice engine does run smooth as ever ?? any ideas
Old Feb 8, 2010 | 04:26 PM
Jon316G's Avatar
Grasshopper
You might be able to get the code read at Autozone (free) even though the light isn't illuminated at the time.
There are pending codes that are stored and do not illuminate a CEL until it fails a 2nd time.
But I'm willing to bet its going to be a misfire code and you'll need to replace the spark plugs and/or coils.
Old Feb 8, 2010 | 05:10 PM
nx04's Avatar
zoom-zoom
thanks for the info man my friend is a mechanic but hes a truck man , he doesnt know the rotarys im gonna do the plugs and coils , hope that works it seems that its the most frequent problem from what i have searched
Old Feb 8, 2010 | 05:12 PM
Jon316G's Avatar
Grasshopper
Yeah... flashing CEL at high RPMs is usually a misfire.
You can probably get away with just replacing the spark plugs, but keep in mind that the coils and/or ignition wires can also be the culprit.
Old Feb 8, 2010 | 05:41 PM
nx04's Avatar
zoom-zoom
ill have to do a general check hes got a lift at his house so were gonna jack it up and just redo all the little possibilities , gonna do a nice engine flush to make it good as new
