Tiny Turbo?
Old Oct 15, 2009 | 07:27 PM
White_Shadows's Avatar
Tiny Turbo?
I had a project idea on the mind for a bit. Wanted to research cost possibles and whats out there.
So all you turbo gurus that know every model and specs by heart, what turbos are available for as follows.
1. Tiny in size
2. low boost is good, 3-6psi
3. Quality turbo (no trashy 2 employee machine shop special crap)
4. Ball bearing if possible.
Old Oct 15, 2009 | 07:42 PM
arghx7's Avatar
won't be able to run boost that low, wastegate probably won't flow enough unless you have a restrictive exhaust
and you still have all the fixed cost of manifold, exhaust, intercooler, engine management, etc
Old Oct 15, 2009 | 07:52 PM
VS8's Avatar
VS8
4 Cylinder Rotary
6 psi would be fine
Old Oct 15, 2009 | 08:11 PM
chickenwafer's Avatar
Nope
For low boost a GT2871R is an excellent turbo.
But IMO running 3-6psi is pointless, you can get the same effect from nitrous with a much lower cost
Old Oct 15, 2009 | 08:39 PM
I love how everyone immediatly assumes I'm after horsepower.
arghx7 no where did I say i'm a dumby who thinks all I have to do is glue some metal fan to my car to make it go faster. All I asked about was models of turbo. I will clarify, I know the costs, I understand the mechanics and technology behind it. All I want is turbo models.
Chickenwafer thank you for the first part exactly what I asked.
Old Oct 15, 2009 | 08:47 PM
"GT2871R on left, stock SR T25 on the right"
Looking for smaller still though. The GT2871R has some size to it. I'm after small as well.
More like this. Although I'm not sure what turbo this is?
Old Oct 15, 2009 | 08:51 PM
VS8's Avatar
VS8
4 Cylinder Rotary
then what do u want to put turbo on for??? reliability???
Old Oct 15, 2009 | 09:02 PM
mysql101's Avatar
turbo = torque. even at 6 psi it will be a nice step up and you won't need to fill up bottles.
Old Oct 15, 2009 | 09:03 PM
05rex8's Avatar
sold the 8... :(
mitsubishi TD-02
http://cgi.ebay.com/ebaymotors/Turbo...Q5fAccessories
Old Oct 15, 2009 | 09:05 PM
hakuna matata!
Originally Posted by 05rex8
It's soooo cute! Can I put my finger in it?
Old Oct 15, 2009 | 09:10 PM
05rex8's Avatar
sold the 8... :(
sure
Old Oct 15, 2009 | 09:20 PM
Red Devil's Avatar
1. Tiny in size
I've got a different angle to your goal - a positive displacement SC. If you are just looking for a little kick in the seat and have fabrication skills it will lead to full boost by 2000 rpms. The Renesis will take ~5 psi non-intercooled, no problem.
Old Oct 15, 2009 | 09:25 PM
Loki's Avatar
TD04 off a Subaru WRX? They're popular on 1.3-1.8L 4bangers. Slightly smaller than a T25.
If you want to go even smaller... CT12 is a Toyota turbo off the twin turbo Supra. It's pretty small though.. really too small. Even a TD04 would be too small here I think, but heck you asked for it.
But you don't necessarily want a small turbo, even when running low boost... you want a turbo that is big enough not to be a major restriction, but with the right A/R combination to give you boost at a reasonably low flowrate (rpm)... I have no idea what those A/Rs would be for an RX, I never looked into it, but yeah... there is such a thing as a turbo too small.
Old Oct 15, 2009 | 09:27 PM
05rex8's Avatar
sold the 8... :(
maybe it's not for his rx8; it was never clarified
Old Oct 15, 2009 | 09:58 PM
Loki's Avatar
In that case we can go smaller still, Toyota CT9 off a Starlet GT, it's almost too small for the 1.3L 4banger in there. 4efte is the engine code.
Runs out of efficiency at about 200bhp no matter how you turn it. spins to 190,000rpm :P
Old Oct 15, 2009 | 10:00 PM
05rex8's Avatar
sold the 8... :(
the TD02 is way smaller than that
there actually was a TD015....can't find a pic of it tho...
hakuna matata!
If I stick my finger in them will it tingle?
Old Oct 15, 2009 | 11:20 PM
Nope
Get an IHI VF39 turbo off an STi, instant spool.
So if you're not after horsepower, then what are you after?
Old Oct 16, 2009 | 12:04 AM
MazdaManiac's Avatar
GT25
The only turbo Chewie can make look small.
It was almost too small for a low-boost Miata.
Old Oct 16, 2009 | 12:15 AM
zoned's Avatar
rotary user
I bet the dog produces more hp than that turbo. it's so cute :-)
Old Oct 16, 2009 | 12:34 AM
ZumnRx8's Avatar
RX8 & RX7 owner
HKS= all are ball bearing
Old Oct 16, 2009 | 12:42 AM
ZumnRx8's Avatar
RX8 & RX7 owner
All HKS are BALL BEARING!
Old Oct 16, 2009 | 12:45 AM
Spoolin8's Avatar
thats like something you strap on to a weedwacker
Old Oct 16, 2009 | 12:51 AM
ZumnRx8's Avatar
RX8 & RX7 owner
^he said small and the turbo i posted retails for about $1500-1700 (just the turbo)
Old Oct 16, 2009 | 07:45 PM
Just an experiment on effects of boost and fuel mileage. Just to see what I can do with small amounts of boost and playing with the backpressure to see if you can increase gas mileage. I never drive the car so I mean even if it works the cost will far exceed the benefit, but still curious. I'm sure mazda maniac has done something along these lines, but maybe not?
As it is an experiment yeah probably not gonna lay down $1,700 per turbo haha.
Red Devil: I have thought about jackson racings new Rotrex, but I can't get ahold of them they never respond *shrugs*, but I've been hesitant as the tug on the motor down low would loose the benefit of torque allowing for more efficent gearing.
Here is an article about a prius owner doing something similar. http://autospeed.com/cms/title_The-S...4/article.html
I know thats piston and CVT, but thats why I'm curious what can be done with a rotary.
Also look at it this way. Ok yes emissions blah blah, but ok we have the newer engine more efficient. Then why in 1993 did the TT RX7 have the same average gas mileage? Also FD's are 5 speed tranny. Having the extra gear I should be able to improve on the numbers.
