RPM increase aft change to manual transmission
Old Oct 13, 2009 | 12:21 PM
Veil_Side's Avatar
on an auto at the speed of 100KM/H the RPM used to be at 2000.
now after change to manual transmission, the RPM is at 3000 for 100KM/H. Is this normal ?
Old Oct 13, 2009 | 01:59 PM
kersh4w's Avatar
Hit & Run Magnet
yes.
congrats on making the switch.
Old Oct 13, 2009 | 02:04 PM
hakuna matata!
different gearing, of course it will be.
Old Oct 13, 2009 | 02:05 PM
RIWWP's Avatar
Didn't mention what gear. If that is MT 3rd gear, that sounds right. Can't speak for the AT RPM.
Not many transmission swaps that I have seen, gratz, and we would be interested in more details
Old Oct 13, 2009 | 02:08 PM
JTtheDude's Avatar
4spd or 6spd AT? If 4 there is definitely a change.
Old Oct 13, 2009 | 02:19 PM
Lord ET's Avatar
Is that a bike rack?
6speed every 1krpm is roughly 20mph. 20 * 3 = 60...so 62mph = 100km/hr @ around 3krpm
Old Oct 14, 2009 | 03:11 AM
Veil_Side's Avatar
Car specifications:
Greddy Turbo Kit
Microtech LT10s
When using 6AT
No RPM cut
Speed cut at 180kmh (throttle off)
Boost kicks in in 2500rpm
Rpm between the 2000rpm to 3000rpm when at about 100kmh to 120kmh
After swapped to 6MT
RPM cuts at 9000rpm
No speed cut
Rattling noise heard from gearbox/clutch when above 5000rpm
Turbo can be heard spooling, blowoff also heard, however no turbo "pull" felt when driving. (as compared to driving 6AT)
Defi boost guage indicates very low (0.1 to 0.3 bar) boost
when in 6th Gear, travelling at about 106kmh, RPM is about 3300
Sometimes when in the 6th gear, car suddenly loses power and starts to vibrate rather violently when taking foot of the pedal. Funny noises heard from gearbox/clutch area. This is done when RPM is at 3k+ rpm. However when stepping the pedal again, vibration & sound is gone, but car feels very underpowered.
i am still using the same dashboard display (0 to 9000rpm) however have plans to install aftermarket tachometer.
is this just a case of the need to re-tune the car after AT to MT swap? or is the gearbox fucked?
Please help.
Old Oct 14, 2009 | 12:00 PM
kersh4w's Avatar
Hit & Run Magnet
when i let off the gas when cruising, my exhaust will emit a few pops. it is "rather violent" though.
where do you live? maybe we can get a local member to help you out. the noise at 5000rpm may be your throw out bearing.
Old Oct 14, 2009 | 09:25 PM
Rmarques's Avatar
Roy M
if your car is jerking violently .. it may be coils .. shtt was happening to my car .. scared the crap out of me .. but im guessing you knew that .. im a noob
Old Oct 10, 2010 | 01:19 AM
Roy1989's Avatar
Originally Posted by Veil_Side
Car specifications:
Greddy Turbo Kit
Microtech LT10s
When using 6AT
No RPM cut
RPM cuts at 9000rpm
No speed cut
Please help.
Yes i do have the similar problem! I have a manual 6mt rx8, but engine overheated, so i ordered a new engine, but by mistake, its actually a 6 port 6at engine, and i using carbonetic super single clutch, and totally same experience of what you r mentioned with the jerking sound and feeling. RR please comment.
Old Oct 10, 2010 | 03:56 AM
crave4speed's Avatar
Perfectly normal. In fact, should be about 95 or 96km/h at 3000 in 6th gear on a stock gearbox assuming gearbox is from a pre-facelifted model with no change in final drive ratio.
Old Oct 10, 2010 | 04:39 AM
Spinning Sushi's Avatar
I <3 Sushi
This should help....
It's in MPH.
Attached Thumbnails RPM increase aft change to manual transmission-speed-rpm.gif
ASH8
Oct 30, 2021 12:50 PM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
akagc
Aug 11, 2015 07:07 PM
CRAZ8
Jul 22, 2015 10:02 AM
