Cyberdyne Gauges
Old Oct 11, 2009 | 11:02 PM
laythor's Avatar
I zoom therefore I am.
Cyberdyne Gauges
So I finally broke down after reading Jedi's Racing Beat Gauge pod thread, and installed my own set. Here's Jedi's original thread: https://www.rx8club.com/series-i-interior-audio-electronics-24/diy-rb-gauge-pod-nordskog-digital-gauges-133938/
I went with the RB gauge pod but picked Cyberdyne gauges after unsuccessfully trying to purchase Nordskog. Apparently they have been bought out and, for the time being, have ceased operations indefinitely.
First, drain your oil. I find having a friend do most of the work while you take pictures and smoke cigarettes is a very great way of doing this:
Hmmm... is that Royal Purple? Why yes it is. I've run nothing but dino oil since I bought that car, figured I'd give RP a try.
The oil filter was being a bit of a pain in the ***, but nothing a long screwdriver and lots of fun can't fix.
The RB water temp adapter as well as the oil plate are things of beauty, the machining is just top notch. Here's a shot of the water temp adapter installed.
Here's the oil adapter installed. It doesn't show the grounding wire we installed later... yeah, we forgot until after the install was almost complete.
This is a shot of what I consider the weakest part of the RB gauge pod. It is curved much like our stock ash tray face plate, but gauge are not curved. This leaves us with two issues. Most standard methods of mounting gauges will not work and we'll be left with some gaps on the sides. Black silicone to the rescue!
It no only fills the gaps nicely but it will also hold the gauges firmly in place. If i ever need to replace a gauge a simple trim with an exacto blade will free the gauge.
The Cyberdyne gauges come with memory recall of HI and LO. It uses a small switch for each gauge. Since we had time and I just wanted to get a feel for the feature we installed it this way. I'm planning on getting different switches and a new blank, so don't mind the less the straight or centered install.
Almost done, time to turn on the car and make sure everything works
All buttoned up and looking nice
Here's a short video of the HI/LO feature of the gauges. Not sure what the red streaks are, maybe aliens in my car or something.
[EMBED]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/V-t_9Wy4w60&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/V-t_9Wy4w60&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/EMBED]
https://www.rx8club.com/attachment.p...1&d=1255320258
Old Oct 11, 2009 | 11:03 PM
chino0314's Avatar
pure sex good right up
Old Oct 11, 2009 | 11:05 PM
Looks good.
Old Oct 12, 2009 | 12:54 AM
laythor's Avatar
thanks
Old Oct 12, 2009 | 02:40 AM
NgoRX8's Avatar
they look awesome!
Old Oct 12, 2009 | 10:18 AM
CyberPitz's Avatar
Huge hole is huge
Very very nice!
Old Oct 12, 2009 | 07:35 PM
laythor's Avatar
I'm really liking them. It's nice not having to scroll through the AP menu to check water temp and then back to afr's. Also seeing the Oil pressure is pretty interesting.. i've been reading all the oil threads and seeing the actual pressure at different RPM's is nice.
Old Oct 13, 2009 | 11:33 AM
8rotor8's Avatar
Back in the day...
Great work.... uhhh.... Zach!
Old Oct 13, 2009 | 11:38 AM
laythor's Avatar
in all things there needs to be a supervisor.. that was my role here.
Old Oct 13, 2009 | 05:28 PM
tournapart's Avatar
Your Mom is ******
Spectator...not supervisor
jk, hahaha...
Good times, was a fun install, I know that ACE hardware like the back of my hand now
Still love the ghetto ziptie washer on the coolant bypass
Old Oct 13, 2009 | 05:30 PM
tournapart's Avatar
Your Mom is ******
yeah but electrical gauges dont have the resolution that mechanical guages offer...
What a crock of ****, yeah, springs and wax thermo pellets with some bubble gum and paper clips versus a printed circuit board...right
Old Oct 13, 2009 | 09:07 PM
tekk220's Avatar
http://www.nordskogperformance.net/home.php?cat=8
they appear to have the gauges here...
Old Oct 13, 2009 | 09:29 PM
elf's Avatar
elf
What pointy ears?
Those look nice! Good job, laythor.
Old Oct 14, 2009 | 01:39 AM
laythor's Avatar
thanks elf.. i've been wanting these for awhile
Tekk.. nordskog still has their online store running, but if you place an order you'll get an email the next day stating they are indefinitely ceasing operations.
Zach, I'm still baffled by Racing Beat suggesting mechanical gauges are the way to go, not sure if they just got a great deal on them so that's why their premade kit comes with them or what.
Old Oct 14, 2009 | 02:30 AM
tekk220's Avatar
I would have to agree that mechanical gauges are the way to go. They are more precise and reliable. I still might get these gauges u got.. they look good
Old Oct 14, 2009 | 09:45 AM
tournapart's Avatar
Your Mom is ******
as far as accuracy and precision goes, its neither here nor there, more has to do with the amount of R and D a company has invested, or "borrowed"
on the comprehension side, whats easier to read while driving? an analog scale and a needle or a straight up number?
Reliability? solid state electrical systems by far outlast mechanical systems, no moving parts, nothing to wear out, nothing to fall out of calibration
I dont mean any offense, I just strongly believe that electrical gauges are the way to go in the 21st century...
Old Oct 14, 2009 | 12:40 PM
NgoRX8's Avatar
I agree, these days electrical gauges are essentially the way to go.
analog v digital is a different story. the terms gets misused pretty often. electrical gauges can be analog as well, and most are.
Old Oct 14, 2009 | 03:02 PM
Lookin' good Laythor! congrats on getting these installed, they look pretty sharp, especially with your current interiour setup.
Old Oct 14, 2009 | 10:38 PM
laythor's Avatar
yep.. can never have too much blue!
Old Oct 14, 2009 | 11:27 PM
do they dim when you turn on the headlights?
Old Oct 14, 2009 | 11:30 PM
laythor's Avatar
yep, the go to about half strength
Old Nov 24, 2009 | 08:46 PM
laythor's Avatar
update on these gauges.
AVOID THEM LIKE THE PLAUGE. All three gauges have now lost parts of their display. Cannot get a response from the guy who sold them or the company that makes them to utilize their "lifetime warranty"
DO NOT BUY THESE GAUGES!!!!!!
Old Nov 24, 2009 | 09:05 PM
oh crap!
sorry to hear this Laythor, good luck with that 'warranty', hopefully someone will eventually get back to you and resolve this.
Old Nov 24, 2009 | 09:52 PM
mscamp02's Avatar
Blue Bullet?
oh man sorry to hear that....they looked damn good to
Old Nov 26, 2009 | 10:47 AM
laythor's Avatar
I'm not holding my breath for anyone to get back to me on this. Think I'll be chalking it up to one of those "life lessons".
On the up side I've decided to replace them with Defi gauges. The local rotary shop, Rotorsport, carries them and the owner is just an all around great guy. I'm planning on having him install them when my replacement BHR midpipe arrives.
http://www.defi-shop.com/product/rg/rg_top.html#movie
