Front 02 sensor gone - runs the same?
Old Oct 11, 2009 | 01:28 PM
Frosty288's Avatar
n0 pants
Through a series of unfortunate accidents I would not like to go over, the front o2 sensor (wideband) which is supposed to be used for fuel trims, etc. Isn't there any more.
Though, after this happened, the car runs the same? I always had a deadening of power after about 6.5k RPM's, but the car behaves the same despite not even having an o2 sensor.
Does this mean the sensor was dead in the first place?
Old Oct 11, 2009 | 03:03 PM
It will run......really rich (in open loop all of the time)....
At high loads it should run the same...so likely not your only problem
Old Oct 11, 2009 | 03:05 PM
05rex8's Avatar
sold the 8... :(
you would get a cel if it was bad
please don't drive the car without the front o2 sensor
Old Oct 11, 2009 | 03:25 PM
Frosty288's Avatar
n0 pants
I had just bought the car so i'm working on it. Any instructions on replacing the front o2 sensor? I tried to follow the wire but always lost it.
Old Oct 11, 2009 | 03:28 PM
It's on the exhaust manifold ...the plug is up behind the oil filter on the top of the engine....square grey plug....
tbiggybig
Aug 13, 2016 06:30 PM
Eirulisse
Aug 15, 2015 12:34 PM
akagc
Aug 11, 2015 07:07 PM
yapakanichi
Jul 20, 2015 02:17 PM
