clutch bracket broken now welded...fixed but car won't start
Old Oct 10, 2009 | 09:53 PM
tskeltonPGA's Avatar
SC clutch bracket broken now welded...fixed but car won't start
ok so i have searched and couldnt find what i did wrong
i took the clutch pedal out and welded the broken bracket and welded the other one that looked like it was starting to seperate
i put the pedal back in and the car shifts great...only one problem
the little gray actuator/plastic (don't know what to call it) piece that lets the car know if the clutch is engaged or not will not press all the way in via the pedal. to start my car i have to get under the dash and push this piece in and turn the key at the same time. it will go all the way in when i push it but the pedal is not pushing it all the way in.
i know i can rig up something tomorrow to make it work but i don't really want to just rig something up...i would prefer to fix it
any ideas?????
thanks!
Old Oct 10, 2009 | 10:09 PM
You gotta pull the grey piece all the way out.
Old Oct 10, 2009 | 10:17 PM
@!!narotordo's Avatar
FLAME ON!
EDIT beat me to it
Old Oct 10, 2009 | 10:55 PM
expo1's Avatar
He's as bad as Can
The thread below contains a photo of how to rig it if needed.
https://www.rx8club.com/series-i-tech-garage-22/connector-identification-under-dash-124276/
Old Oct 11, 2009 | 01:28 AM
pull the grey switch out , you might feel some "click click click", but dont worry you're not breaking it.
Old Oct 11, 2009 | 09:36 AM
it won't pull out at all...i actually pulled the entire thing off! nothing broke but i think i may have to rig it. any idea why it won't reach now?
Old Oct 11, 2009 | 09:41 AM
ok so after taking the entire piece out of the car i was able to easily pull it out a few clicks and its good to go! thanks guys!
Old Oct 11, 2009 | 10:53 AM
Huey52's Avatar
Registered Zoom Zoomer
I inadvertently overly compressed my starter interlock switch as well when reinstalling the clutch bracket. I used a 16-22 awg spade connector inserted into the socket (shown in expo1's link) as an electrical bypass until I had a chance to remove and fix the switch as you now have. I now carry that connector in the glove box, just in case.
Old Dec 25, 2009 | 06:56 PM
8upbad's Avatar
Jared
omg this thread just saved my Christmas
Old Jan 26, 2010 | 03:34 PM
Soco's Avatar
I'm headed to pay basically 500$ for a broken clutch pedal bracket. I filed my complaint with nhtsa as you should too so they issue a recall. Gentleman said they are investigating this issue still. If they issue a recall we're also entitled to a refund so, please file. Casualty of war until then.
Old Dec 13, 2013 | 07:31 PM
Cmac2929's Avatar
This worked perfect, thumbs up
Thanks Chris
Wantingtoknow
Dec 15, 2016 02:25 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
RX7.9
Jul 20, 2015 12:01 PM
