Replace actual heater core vs. entire HVAC AC/Heater unit
Old Oct 6, 2009 | 03:47 PM
wowo76's Avatar
NJ Replace actual heater core vs. entire HVAC AC/Heater unit
My heater core is busted and I am left with the reality the my dash will have to be torn down to get heat for the winter.
I have an actual heater core which would require the dash and the HVAC system to be disassembled. On the other hand, I may be able to pickup an antire HVAC unit (attached to the reinforcement bar) which would require the disassembly of the dash and only the removal and replacement of the HVAC system.
Which path should I take? (The answer does seem obvious, but still)
Old Oct 6, 2009 | 05:08 PM
Take the first path.
Its not hard to take the whole dashboard apart, I did it before. Its just very time consuming.
Just dont loose any bolts/nuts in the process. and remember where they go.
ASH8
20
Sep 26, 2022 11:55 PM
Redheddude222
Aug 24, 2015 09:14 AM
ion_four
Jul 30, 2015 09:48 PM
escapedan
Series I Do It Yourself Forum
Jul 29, 2015 10:44 PM
mazdaverx7
Jul 21, 2015 07:31 PM
