West RX-8 Forum Serving CA, NV, AZ, HI
High mileage in CA, NV, or AZ
Old Sep 25, 2009 | 02:45 PM
RX8HD's Avatar
Does anyone living in Southern Cali, NV, or AZ have an RX8 with high mileage (75,000 or more) on the original engine? If so, what kind of gas? oil? premix? My RX8 in Cali just failed the compression test with Mazda Corporate on the line, and the dealership says there's nothing that can be done to prevent it in hot climates.
Old Sep 25, 2009 | 02:56 PM
philipchan's Avatar
82K on my 8......SoCal
but second engine already
Old Sep 25, 2009 | 03:24 PM
scremn8's Avatar
the more things change
go with bhr coils that will help.
but if it really is low then they have
to replace your engine. mazda
extended the warranty to 100 000
miles.. most heat related issue's
generally point to the coils
Old Sep 25, 2009 | 04:17 PM
nikkdizzle's Avatar
Daddy's Home...
that shouldn't be a problem....the engine is covered by the 100k warranty...but as stated above, anything heat related is probably coils...
Old Sep 25, 2009 | 05:12 PM
timja's Avatar
I have a 2004 Auto with 95,500 miles. It's on the original engine too. No problems so far, I just use premium gas and maintain the oil with GTX high mileage 5w30.
Old Sep 25, 2009 | 07:04 PM
RX8HD's Avatar
Timja, that's impressive. Are you loyal to a particular brand of premium gas? Have you always used 5w30?
Old Sep 25, 2009 | 08:22 PM
timja's Avatar
I usually use Shell or Mobile but I don't think its too big of a deal. I bought the car when it had 60k on it and started using 5w30 from then on.
The only issue I have had is when I modded my car with an AEM intake and HKS Hi-Power exhaust. I would frequently stall on hot days and throw up a code: P2070 (SSV stuck open) Since then I've just gone back to stock and its been great!
Old Sep 25, 2009 | 10:50 PM
maxprelude92's Avatar
04 6MT BB
I bought my '04 w/ 36,000 miles on it. Now it has 85,500. I use Shell V-power almost exclusively, as well as Idemitsu premix. I generally use 5W-20 conventional oil with the occasional quart of 5W-30.
Old Sep 26, 2009 | 12:40 AM
elf's Avatar
elf
What pointy ears?
144600 miles on original engine, Cheveron Premium, RP 10W-40, I don't primix, routine maintenance (oil/filter change, sparkplug change, diff/tranny oil change, etc.)
2006 GG Shinka
Old Sep 28, 2009 | 11:22 PM
RX8HD's Avatar
Well done sir. That's an inspiration. I had used almost entirely Mobil regular 87 gas so I wonder if that was a factor to my engine failure. The good news is the new engine was totally free with no hassles from the dealership.
Old Sep 29, 2009 | 12:19 AM
ZachLegend's Avatar
2006 GG Shinka
Old Sep 29, 2009 | 01:02 AM
trancesimulator's Avatar
i have 77,000 on mine 1st motor no premix castrol 5-20 in winter 5-30 in summer always chevron 91 gas just had my compression done at sevenstock and 107 front rotor and back 103...
Old Sep 29, 2009 | 07:10 AM
scremn8's Avatar
so after them telling you there was nothing they could do.
you went back and had a talk with them on what you found out
here, and they gave in for the engine replacement..
glad we could help.
Old Sep 29, 2009 | 10:27 AM
iLikeEatPoo's Avatar
The Great Dick
2004 82k Miles and over 300 track miles on original motor. running 5w30 castrol gtx and 5 caps of premix every fill up with the OMP still installed.
Old Oct 5, 2009 | 10:34 PM
Spirograph's Avatar
AZ
Someone recently told me that running premium is extremely important in rotary engines due to the fact that the higher octane gas keeps the combustion chamber temps much lower. Anyone know if that's true?
Old Oct 5, 2009 | 10:56 PM
c0ldf1ame's Avatar
closing in on 70k this month, so far so good, but think my coils and plugs are due for a change soon, using mostly shell and cheveron 91 and 10w-30 regular oil, no premix
Old Oct 6, 2009 | 06:51 AM
scremn8's Avatar
if you have the money. up grade you coils.
Old Apr 24, 2010 | 01:43 PM
RX8.PIPE.DREAMS's Avatar
Rotary Junkie
Bumping from the dead hoho.
I am @ 107k. Brought the car with 104.5 k. Had brakes, diff., tranny fluid, oil change done since having the car. Use Idemitsu 4 oz premix, and shell v-power 91.
-elf: If you want to update us with info about your mileage and habits, feel free to go over to
https://www.rx8club.com/rx-8-discussion-3/highest-mileage-2004-original-original-engine-165164/ -It would be greatly appreciated.
-Chris
Old Apr 26, 2010 | 09:48 AM
jordanjerome's Avatar
ruthless8
112k and 3 engines in the process. god I cant wait to sell this BEA-Utiful car.
Old May 4, 2010 | 05:54 PM
seagram14's Avatar
I have 2005 6MT with 87,500 miles on the original engine. Used only shell or cheveron 87octane gas(I do not use any other brand of gas). My car is use to 87 octane because that is what I have been using. If you always used 91 octane then stick the 91 octane because your car is use to it. I heard some where is ok to increase the octane gas level that your engine is use to but it is not good to decrease the gas octane level the you engine is use to. I change the oil every 3000 miles with castrol 5-20. No premix what is that anyway? Change the plugs at around 55,000 miles. I have an AEM cai system and get around 16 to 17 miles in the city and 19 to 20 on the highway. Mileage might be better if I did not have the AEM cai system and was not running in 19x9.5 wheels with 255/19/35 tires on front and back.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
