early fuel cut off issue
Old Sep 24, 2009 | 07:31 PM
rarbogast21's Avatar
I just bought a 04 rx8 and it wont accelerate past about 7700 rpms in any gear. The are no codes being set off. all seems normal except for that one issue. Any ideas or similar experiences? Please help if you can. Thanks
Old Sep 24, 2009 | 07:33 PM
Jon316G's Avatar
Grasshopper
Clogged cat?
Possibly the usual coils, plug wires, and/or plugs.
How many miles on your car?
Old Sep 24, 2009 | 09:23 PM
I8U's Avatar
I8U
^+1, also could be failing fuel pump.
Old Sep 25, 2009 | 04:21 PM
the car has 61k on it. It also is a bit slow on starting. thanks for the help so far.
Old Sep 25, 2009 | 04:32 PM
I8U's Avatar
I8U
carbon build up, old starter...time to start learning how to work on it yourself. It's fun to work on this car...
Old Sep 25, 2009 | 04:43 PM
carbon build up where?
Old Sep 25, 2009 | 04:44 PM
I8U's Avatar
I8U
Inside the engine...
Old Sep 25, 2009 | 04:54 PM
thanks for the help. i dont know much about these cars and how they work. so its a learning experience. I run the car with 93 and keep the oil up. what part do i change for the fuel pump? the whole housing?
Old Sep 25, 2009 | 05:15 PM
I8U's Avatar
I8U
You'll have to swap out the entire fuel pump, they run about $150 new.
Old Sep 25, 2009 | 05:16 PM
Old Rotor's Avatar
If it is an automatic thats when the fuel is cut off......normal
Old Sep 25, 2009 | 05:48 PM
it's a manual
Old Sep 25, 2009 | 06:01 PM
rexybrad's Avatar
did you take the car for a test drive?
was the car bought from a dealer or a private sale?
is it the six speed version?
how long have you owned the car and have these symptoms allways been present?
Old Sep 25, 2009 | 06:33 PM
the car was bought from a dealer. it is a 6 speed. i did test drive it but didnt red line it. I noticed it the first time i really got on it and tried to red line it. what are your thoughts?
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Rote8
Sep 7, 2015 02:17 PM
wanted797
Aug 26, 2015 11:24 PM
tbiggybig
41
Jul 22, 2015 11:47 PM
