v-leds running lights
Old Aug 31, 2009 | 09:52 AM
Hesselrode's Avatar
US Navy Rotary Enthusiast
do I need to put a resistor in line with the running lights the little lites in the headlamp unit? anyone had any problems with these? I am also running the third brake light led and the 1194 leds or whatever they are in the brake lights, i am causing the traction and abs lights come on where do i need a resistor and how much? with the normal third brake light it doesn't do this but with all leds it does.. can i just put one big resistor in the third brake light or do I need in all brake lights?
Old Aug 31, 2009 | 01:20 PM
Aipex8's Avatar
X e p i A
No resistors needed for the parking lights. Unfortunately, I used the high power LED bulbs for my brake lights and didn't end up getting any errors from having all LEDs. V-LEDS did suggest the following resistor before I purchased mine.
http://www.v-leds.com/BlinkerWarning...81145-1-3.html
You should just need one, and you should be able to put it on any of the brake lights, I would suggest the center one.
Old Aug 31, 2009 | 04:00 PM
Hesselrode's Avatar
thanks aipex8 i am using the replacement third brake light..
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
drebbrnator
Dec 27, 2018 07:02 PM
SUKIEE
Oct 9, 2017 09:41 PM
akagc
Aug 11, 2015 07:07 PM
