Which parking lights?
Old Aug 17, 2009 | 01:05 PM
ddtran46's Avatar
Hi guys. I am going to buy a pair of parking lights soon, but would like some inputs on these.
http://cgi.ebay.com/ebaymotors/RX-8-...Q5fAccessories
or
Does anyone have any pictures of these installed? I would like to see the difference between the two.
I don't want the parking light to be alot brighter than the stock HID's.
Old Aug 17, 2009 | 01:16 PM
08boostedmzda's Avatar
You might take a look at the ones from rx8strakes.com. Rx8trakes is a forum vendor and have some really great products. I have their LED parking lights and love them.
http://www.rx8strakes.com/index.asp?...ROD&ProdID=415
Old Aug 17, 2009 | 01:22 PM
ddtran46's Avatar
Thanks. I think that Rx8strakes is the same seller as the ebay link I've shown.(it says it on the bottom of the screen). How much was shipping with Rx8strakes? You bought the 6 Led bulb set?
Old Aug 17, 2009 | 06:12 PM
Aipex8's Avatar
X e p i A
V-LEDS parking lights are a little cheaper, plus there is a 15% discount for rx8club members, plus they use .5 watt LEDs that are BRIGHT! For more info see my thread here:
https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/new-leds-wow-bright-158590/
A link to the lights I use:
http://www.v-leds.com/Interior-LED/D...-p5768269.html
My parking lights:
Old Aug 17, 2009 | 08:16 PM
ddtran46's Avatar
Thanks for the link Aipex8.
I've read that the parking light can come loose and get stuck in the head light. Does this happen to the Rx8strakes bulbs? I'm close to buying it.
Old Aug 17, 2009 | 08:52 PM
ddtran46's Avatar
Anyone?
Old Aug 17, 2009 | 08:58 PM
cyclone1208's Avatar
yea i bought by pkg light bulbs from rx8strakes and they are a lil loose when u put em on.....just wrap tape over at the end to hold it tight and u should be fine
Old Aug 17, 2009 | 09:02 PM
ddtran46's Avatar
The bulb disconnect from the connector or is it still attached?
Old Aug 17, 2009 | 09:55 PM
Aipex8's Avatar
X e p i A
The VLEDS bulbs have a very thick base and are not loose in the socket.
Old Aug 17, 2009 | 10:53 PM
ddtran46's Avatar
Ok thanks. I just bought the one you showed me.
Old Aug 20, 2009 | 08:13 PM
ddtran46's Avatar
Is there a way to install the parking lights without removing the front bumper?
Old Aug 20, 2009 | 08:24 PM
Aipex8's Avatar
X e p i A
You don't remove the bumper for parking lights. You should be able to remove the fuse box cover on the drivers side, and the ECU cover on the passenger side then reach in and you should be able to feel the back of the socket. Twist counter clockwise. There may be a DIY thread with some pics.
Old Aug 20, 2009 | 09:27 PM
ddtran46's Avatar
Thanks alot Aipex8
Old Aug 20, 2009 | 09:51 PM
ddtran46's Avatar
Just finished installing it and it took me less thank 30 minutes.
Old Aug 20, 2009 | 10:45 PM
Aipex8's Avatar
X e p i A
Sweet! Those look great.
Old Aug 20, 2009 | 10:48 PM
cidvicious831's Avatar
nice!!!
Old Aug 20, 2009 | 11:12 PM
ddtran46's Avatar
Aipex8..you bought your fog bulbs from the same seller correct?
Old Aug 21, 2009 | 12:12 AM
Aipex8's Avatar
X e p i A
Yep
Old Aug 21, 2009 | 12:16 AM
Spinning Sushi's Avatar
I <3 Sushi
Just make sure you buy some quality parking lights or else the heat from the HID's will kill them. Happened to two of my super bright ebay sets, learned my lesson, and bought some PIAAs.
Old Aug 21, 2009 | 12:25 AM
ddtran46's Avatar
What is PIAA?
Old Aug 21, 2009 | 12:27 AM
I <3 Sushi
Have you been living under a rock or something?
PIAA is a brand, one of the best brands in automotive lighting.
Old Aug 21, 2009 | 12:29 AM
I <3 Sushi
http://www.piaa.com/
Old Aug 21, 2009 | 12:51 AM
ddtran46's Avatar
I guess I have. lol
Old Aug 21, 2009 | 08:58 AM
lopezian2004's Avatar
Master Shr3dd3r
Looks good man. V-Leds also has some fogs you can buy to match your parking lights and side markers. Just check out Aipex's "WOW these LEDs are freakin bright!!!" thread or whatever its called
Or you could just do an HID conversion or HID projector conversion like I did
Both options look great
TeslaMSI
Dec 10, 2015 01:10 AM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
