How to reset A/C?
Old Aug 10, 2009 | 09:10 PM
Spirograph's Avatar
How to reset A/C?
I tried resetting the A/C, but it didn't work for me - the rear defrost light never gave me 3 blinks confirmation. I pressed and held the recirc and front defrost buttons, held for 3 seconds after turning to ACC, then continued to hold for 3 seconds after turning ignition to ON, but no blinking light. What am I doing wrong?
Old Aug 10, 2009 | 09:57 PM
Chavy's Avatar
I did it for the lulz
its just the one on the left and the recirculate
Old Aug 10, 2009 | 11:53 PM
Spirograph's Avatar
right, I'm pressing and holding the left defrost and recirc buttons, but the right defrost button is supposed to blink 3 times to confirm that it worked, and mine's not doing that.
Old Aug 11, 2009 | 12:00 AM
SPHINX144's Avatar
in what circumstances does the a/c requires to be reset?
Old Aug 11, 2009 | 12:01 AM
rodjonathan's Avatar
silent assasin
^+1 just wondering
Old Aug 11, 2009 | 12:03 AM
Krazed_Rx8's Avatar
^Beats me, didnt even know we could do that
Old Aug 11, 2009 | 12:08 AM
Jon316G's Avatar
Grasshopper
Easier to just copy/paste this:
AC NOT COOL (AFTER 9/11/03 PRODUCTION)
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 40118171 ********
Some customers may complain of lack of AC cooling from the vents. This may be caused by the intake air selector (recirculate / fresh) in the "FRESH" mode. Cooling the interior of the vehicle may take longer if the air intake selector is in the "FRESH" mode. Maximum cooling is achieved when the intake air selector mode is in the "RECIRC" position. The AC amplifier can be programmed to automatically default to "RECIRC" mode when the following conditions are met:
1. Ambient air temperature is 68 deg. F or higher.
2. HVAC control mode is in "FACE" mode.
3. HVAC temperature is in maximum cool setting. Customers with this concern should have their vehicle repaired using the repair procedure. NOTE: Vehicles produced before 9/11/2003 are not programmable and should have the AC amp replaced per Service Bulletin # 07-002/04
1. Verify concern.
2. Verify ignition switch is in OFF position.
3. Press and hold the front defrost and air intake selector buttons simultaneously.
4. Turn the ignition key to the "ACC" position for 3 seconds. (Continue to hold the buttons down from step #3.)
5. Turn the ignition key to the "ON" position for 3 seconds. (Continue to hold the buttons down from step #4.)
6. Successful programming will be confirmed by the rear defrost indicator light flashing 3 times. NOTE: If vehicle's battery dies or cables are removed, the programming will not be retained and must be performed again.
Old Aug 11, 2009 | 12:10 AM
silent assasin
oh i see so if its automaticall on recirc then im good to go?
Jon316G's Avatar
Grasshopper
His rear defrost light probably isn't blinking while performing the reset because the AC amp is already defaulted to "RECIRC"
Old Aug 11, 2009 | 01:06 AM
Chavy's Avatar
Originally Posted by Spirograph
right, I'm pressing and holding the left defrost and recirc buttons.....
no it's the recirc button the lower left one not both
Old Aug 11, 2009 | 01:02 PM
Nubo's Avatar
Lubricious
Remember, that is an old bulletin. At some point after that, the amplifier was changed, iirc. So that procedure may only apply to 2004,2005 or so, but I can't say for sure. Mine is 2004 and needs that procedure, which I have renamed the "Set AC to secret, non-suck mode" procedure.
Old Jul 22, 2018 | 05:40 PM
longpath's Avatar
It appears that the bulletin does not address models made before September of 2003, such as my own which was made in July of ‘03. Oh well, had to try.
Old Jun 23, 2024 | 06:08 PM
My_daily-rx8's Avatar
Yo just a heads up my 04 did not display any blinking light but I did get an audible alert. Worked amazingly. Been drivin in phx traffic all summer with no a/c only to realize this was the only problem.
theguy1991
Aug 1, 2018 02:23 PM
silkd
Jan 27, 2010 02:26 PM
bmccarthy
Sep 26, 2008 12:42 PM
rpiekarczyk
11
Jul 10, 2006 11:36 PM
pret
West RX-8 Forum
Dec 21, 2005 05:20 PM
