transponder wires?
Old Aug 1, 2009 | 12:19 AM
aa10's Avatar
Thumbs up transponder wires?
oky guys here's a hard question....
well, i started to mod almost everything on my 8 ..so a i decided to finally to hook up my remote starter.. its been some thing i been planing for years (its part of a bigger plan). but anyways i hooked up all the remote starter and the car starts fine and works fine....however i decided to go ahead and start working on the transponder bypass module..(you know why...)
But i took the transponder coil (antenna) off and i cant find the TX and Rx wires....i only see the ground wire. i have four wires but i don't know which is which.....
does anyone know the wire scheme for RX8 transponder coil ?? ....
Here is a few transponder module that i found on the net..(almost the same as mine)
http://www.bypasskit.com/manuals/104...0_D01_I_EN.pdf
http://www.idatalink.com/pdf/viewDoc.php?id=403
http://www.bypasskit.com/getdocument...documentid=234
Old Aug 2, 2009 | 12:29 AM
aa10's Avatar
Thumbs up
oky, i finally figure it all out....
the RX-8 2005 uses ford fusion wiring diagram @ the transponder antenna and i think ignition switch. i don't know why but the wiring diagram for rx8 (@the ignition switch and transponder) was not the same as my rx8...however it more like ford fusion...i don't really know why but i guess if anyone every had the same problem then at least this can help them..
p.s. the connection type is E NOT D at the antenna coil
...hope it help someone one day...
Thanks ALLLL...
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
