What to do? Rear Lower Tie Rod bent
Old Jan 4, 2004 | 04:19 AM
Efini 8's Avatar
no pistons!
my rear lower tie rod is bent (one connecting the wheel hub to the mid section with a little screw with a dial on it) where to adjust caster I believe. Bent it drifting and I jumped a curb. Was doing a left hand turn then didnt countersteer in time then the oversteer was too great with the rear sliding out then hit the concrete curb with my rear right rim causing the lower tie rod to bent a little hitting the control arm.
Old Jan 4, 2004 | 10:51 AM
Sputnik's Avatar
You should take it to a dealership, have that tie rod replaced, have the rest checked to see if there was any other damage. It's hard to tell sometimes, and unless there is a weak piece in the suspension, more than one piece is normally damaged.
Then get a 4 wheel alignment again.
---jps
Old Jan 4, 2004 | 02:04 PM
syntrix's Avatar
I like cheese!
Yeah, unfortunately it's usually more than one component that gets bent when you whack a curb.
Take it to a dealer or a good body shop (if they even have specs on hte car), and they can check frame, lower carriage, and each of the tie rods, etc.
Hopefully it's not that bad!
Old Jan 7, 2004 | 06:49 PM
Efini 8's Avatar
no pistons!
Here is a pic of the bent rod
Old Jan 7, 2004 | 07:12 PM
Gord96BRG's Avatar
Is the control arm supposed to be curved slightly, or was that also bent?
Regards,
Gordon
Old Jan 7, 2004 | 09:24 PM
Spin9k's Avatar
Momentum Keeps Me Going
Wow! Think of the lateral forces to do that kind of damage! To be able to bend two solid steel bars like that makes you wonder what those forces did to the frame and attachment areas? Yikes!
You might need a body shop frame straightener.
Old Jan 7, 2004 | 10:02 PM
syntrix's Avatar
I like cheese!
They are both bent
You can see in this pic with my lower arm dropped:
Old Jan 8, 2004 | 07:39 PM
Efini 8's Avatar
no pistons!
is that a pic of ur install when you did ur JIC coilovers Syntrix?
Old Jan 8, 2004 | 08:28 PM
syntrix's Avatar
I like cheese!
Yes
Old Jan 12, 2004 | 10:32 PM
Doctorr's Avatar
Ricer is Nicer.....
Cool Rim....
Rim will be bent 'for sho'.
Spin it and watch it wobble.
Bearings will be damaged, need new ones, will last months but will eventually seize up. Please don't ask how I know,,,,
doc
Old Jan 20, 2004 | 07:01 AM
Efini 8's Avatar
no pistons!
fixed it... only took like 30 mins... now need alignment.
Old May 20, 2004 | 12:51 PM
project's Avatar
Get your wheels checked out for cracks as well. I slid into a curb at about 15 mph in an unexpected snowstorm and broke both wheels on the drivers side. Luckily the only other damage was a bent wheel hub....
Old May 25, 2004 | 02:12 AM
RenesisX-8's Avatar
Non-average GearHead MoFo
I had to replace the same two arms on my eight.
The night I bought it, it was about 35 degrees and pouring rain. I got off at my exit and it was not raining and looked dry. I went around my usual fun corner a little conservatively and as soon as I throttled out the car snapped and I locked them down but it went past 90 degrees and crossed the road sliding onto the curb RR first.
I replaced the rods myself, dealer ($112) ordered them the next day (Fri.) and I fixed it on Monday, before the wife found out hehe.
After that the car performed flawlessly. I pushed the car hard on every curvey road and in the mountains.
Old May 25, 2004 | 09:28 AM
darkducati's Avatar
This sounds like an excuse for a call to JIC. :D
Old May 25, 2004 | 10:16 AM
jaybraveheart's Avatar
Unhappy
I did te same thing but my airbag deployed as well
I had to go to the dealer It's been two weeks and they still haven'y gotten parts
Old Nov 16, 2007 | 04:19 PM
roto8car's Avatar
I just did the same thing. car-part.com has the parts listed for $45. A place in OH will ship a rod for $15 extra and it'll be here in 3 days. Tires plus quoted me 260 for the whole job and an alignment. How hard was it to swap the bushings?
Old Nov 16, 2007 | 05:05 PM
BigRed's Avatar
w8nkel
good use of the search button^, but its 3 years old
Old Dec 4, 2007 | 12:03 PM
roto8car's Avatar
figured i should add any info for future dummies
Old Dec 4, 2007 | 12:46 PM
G3tR3DDY2GR3DDY's Avatar
i ususally have quite a few of these laying around from parts cars too if anyone ever needs one pm me
Old Sep 22, 2013 | 05:10 PM
saudkhan's Avatar
mazda rx8 rear tor rods are bend help me please...
my rear driver side tie rods is bent both rods are bend and Tyre is slightly curved. please help me. what can i do for that?
Attached Thumbnails What to do?  Rear Lower Tie Rod bent-photo-1-.jpg   What to do?  Rear Lower Tie Rod bent-photo.jpg
Old Sep 22, 2013 | 06:00 PM
paimon.soror's Avatar
holy rust batman! You are going to need to replace with OEM or aftermarket (megan). Not much else you can do that would be recommended. Check on ebay for a set of oem used from a wrecker, there should be a ton out there (there usually are).
Old Sep 22, 2013 | 06:03 PM
syntrix's Avatar
I like cheese!
I would take it to the dealer or a qualified mechanic.
Must be in a snow state to see that much corrosion, yikes!
Old Sep 22, 2013 | 06:27 PM
monchie's Avatar
I HATE SPEEDBUMPS!
That thing needs to be replace asap, it could just break anytime...
