Found Chassis Code?
Old Jan 9, 2003 | 06:52 PM
B-Nez's Avatar
Found Chassis Code?
Take a look at the following pic under the hood, and look at the metal placard on the firewall:
Maybe I'm nuts, or maybe it's a trick, but it looks like the RX-8 will be the FE17 ?? Whaddaya think?
Old Jan 9, 2003 | 07:06 PM
i think thats what it says b-nez!
Old Jan 9, 2003 | 07:59 PM
Toadman's Avatar
Nomad Mod
Someone post a pic of the door jamb VIN label and specs please! Can't believe we forgot this..
Old Jan 9, 2003 | 10:04 PM
evel333's Avatar
donna toki mo...
I wonder if there will be any suffixes to that like FC3S and FD3S. From the looks of the VIN, definitely an FE, but probably not an FE17, otherwise us third gen owners would be driving FD33s. The next three numbers (looks like 1-7-5) in the above VIN are Mazda's body and engine designation. I don't have a clue which is which, or whether you can use the same formula from other Mazdas to decode them. (briskly rubbing hands together) Now I can plan on that license plate...
Old Jan 10, 2003 | 12:06 AM
B-Nez's Avatar
Didn't forget. One of the shots Boowana sent this week had a close-up of the door jamb sticker -- it was not filled in. Imagine how tormented I felt staring at the "Kg-front/Kg-rear" with blanks!
Old Jan 10, 2003 | 08:35 AM
Sputnik's Avatar
Yep, it was nekked as a jaybird.
But we did forget, and it's lucky that we caught this VIN plate after all.
---jps
Old Jan 10, 2003 | 08:41 PM
BryanH's Avatar
2009 BS Nat'l Champ
If you go to the Specifications page here [ http://www.poweraxel.com/autosalon/as2003/mazdaspeed/ ] just below the main picture is this text:
"MODELFSE3P"
Maybe?
Edit - Okay, that was very odd. I copied the text from the site and it put in an extra letter when the forum processed it. Riiiiiiight. Anyway, what I really see at that page is "SE3P".
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
yapakanichi
Sep 17, 2015 04:23 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
