Signal Switchbacks?
Old Jul 16, 2009 | 10:36 PM
KHANVICT's Avatar
Signal Switchbacks?
im looking if anybody did a mod that your front indicator bulbs are always on, and when you turn they blink
sorta like this
http://www.youtube.com/watch?v=KmUsi...eature=related
Old Jul 16, 2009 | 10:41 PM
Spinning Sushi's Avatar
I <3 Sushi
PM Rotary Rasp, he makes them.
Old Jul 17, 2009 | 01:05 AM
Aipex8's Avatar
X e p i A
You need to have a dual filiment bulb to do this. One that doubles as parking light and signal. For the 04-08 models, the signal is a 7440 (single filiment) bulb. The 7443 (dual filiment) bulb is the same size, so I suppose you could find source a couple of sockets (I would suggest from the tail/brake harness which is also a 7443) and modify them to fit, then tap into the existing parking lights power for the third wire on the new harness.
If you have an 09, just get the switchback bulbs and plug in as they already use a dual filiment bulb.
If you want to do the side marker you are probably looking at a custom build as none of the larger premade switchback LEDs will fit in them.
Old Jul 21, 2009 | 12:21 PM
KHANVICT's Avatar
thanks alot aipex8 ,
does anyone have any pics of an 8 with white signals that are always on??
yurcivicsux
192
Sep 12, 2017 10:54 PM
