XM Wiring HELP!!!
Old Jan 2, 2004 | 06:35 PM
Rotor8U's Avatar
I ROT8
XM Wiring HELP!!!
What wires do I tap into for the ACC and the B+???? I have read the other info from other threads and there are no specifics....
Some have mentioned tapping into the Cigarette lighters....thats fine but there are two connectors...which wires do I tap into????
If anyone has any info PLEASE HELP..because my car is a mess now..and i want to finish this...
Old Jan 2, 2004 | 07:50 PM
Genom's Avatar
Not so Super right now
Your cigarette lighter ahs a large white plug with 2 cables. A red and a black. The red is your acc+ and the black is your ground. You could also tap into any chasis screw, but just used this one. I totally removed my lighter so I just cut the cables and used it for both ACC and Bat. It can be done and for certain reasons I prefered this. If not the stereo cable (large white one) should have an always on cable. The wiring is posted here: https://www.rx8club.com/showthread.p...5&pagenumber=3
Thats it. Plug in your antenna pass-through and give it a try.
Old Jan 2, 2004 | 08:14 PM
Rotor8U's Avatar
I ROT8
GOT IT....IT WORKS...THANKS GENOM
Old Jan 2, 2004 | 09:04 PM
flyboyindy's Avatar
Hey Rotor... sorry I wasnt online when you IM'ed me... I put you on my buddy list... let me know if I can help in anyway...but sounds like you got it all figured out already...
Old Jan 2, 2004 | 10:06 PM
Genom's Avatar
Yay!
:D
BTW, I decided to modify my ashtray by dremel to fit the commander control panel inside the ashtray and have it close. I am not using the bezel that came with the unit, but rather am making on out of plexy to fit the ashtray like a lid. Just need to smooth some edges and 'll have some pics up with measurements in case anybody else wants it.
Old Jan 4, 2004 | 08:11 PM
Rotor8U's Avatar
I ROT8
flyboy....its cool man..thanks...
Genom....Sounds good man...post some pics when you get it finished...Im looking for a good way to flush mount it so the the lid can close as well.
I will try to take some pics of my install soon. I found a great place for the "black box" control module.
Thanks guys
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
