Push Button Start / Keypad Ignition / Proximity Sensor
Old Jun 30, 2009 | 06:06 PM
Donald.Clabaugh's Avatar
Question Push Button Start / Keypad Ignition / Proximity Sensor
Anyone tried this before? Thinking about a keypad ignition with push button start and a kill switch that kills the power to the push button start (backup for bad areas?). As well as a proximity sensor for the locks? I really don't want to have to take my keys out of my pocket.
Is there an online wiring diagram of something like this, or atleast the ignition diagram to give me an idea of what wires are what before I go cut happy...
Old Jun 30, 2009 | 06:10 PM
G3tR3DDY2GR3DDY's Avatar
pretty much any push button start will require you to have the key in the ignition or use another remote. And if you are gonna have another remote to take out and push a button to start it, why not just take the keys out of your pocket?
Old Jun 30, 2009 | 06:21 PM
You walk up to the car, the proximity sensor unlocks the doors. Then you push in your 4 digit code into the num pad which turns the car to "Start/Run" Mode. You then push the "Start" button which engages the starter. But I dont want to start stripping wires if I dont know how they should be set up... I think it would be a pretty bad *** setup, "transporter" style?
Old Jun 30, 2009 | 06:26 PM
Jon316G's Avatar
Grasshopper
With a prox sensor, how will you prevent the car from unlocking when someone else walks near it?
Old Jun 30, 2009 | 06:27 PM
RX8YA's Avatar
WAH WAH WAH
Yeah why would you want your car to just unlock when someone is around? I feel like this thread was written by the transporter.
Old Jun 30, 2009 | 06:29 PM
one condition..
Old Jun 30, 2009 | 06:30 PM
Jon316G's Avatar
Grasshopper
Originally Posted by G3tR3DDY2GR3DDY
one condition..
care to explain
Old Jun 30, 2009 | 06:34 PM
Jon316G's Avatar
Grasshopper
Something like an inductive prox switch wouldn't be a secure idea.
And a photoswitch would be very complicated to tweak (distance and how wide the beam is) and you still have the problem with it picking up anything around it.
Old Jun 30, 2009 | 06:42 PM
HaHa, The proximity sensor only works when you get near it with the remote in your pocket, keyless entry. It doesn't unlock every time someone comes near it.
Push Button Start - http://www.thehoffmangroup.com/keepi...ushbuttonstart
KeyPad Ignition - http://www.asianwolf.com/car-alarm-keypad.html
Alarm/Keyless Entry - http://www.bestbuy.com/site/olspage....=1076628577516
Old Jun 30, 2009 | 06:46 PM
Jon316G's Avatar
Grasshopper
^that explains a little better
I was starting to think you were just buying any old prox switch to throw on your car.
Old Jun 30, 2009 | 06:53 PM
No, I just think it would be a cool project and everyone would be all jealous that I dont use keys? yeah.. BUT, I also what to use a small little kill switch that can kill the power to the start button Most of the time I would just keep it on but I would shut it off on long times of not using the car or when I go downtown DC.
Old Jun 30, 2009 | 06:55 PM
Jon316G's Avatar
Grasshopper
I actually did a Kill Switch project on a couple RX8s:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-kill-switch-166365/
Old Jun 30, 2009 | 06:57 PM
wow, that looks like you know what your doing with that... So do you think this setup is possible?
Old Jun 30, 2009 | 07:01 PM
Jon316G's Avatar
Grasshopper
I think the biggest problem is the Mazda key itself since it has a chip installed.
You need to have it in the ignition switch, and at that point you might as well just turn the key instead of hitting a button.
Old Jun 30, 2009 | 07:21 PM
Don't you have to wire in the valet key? I know that with the remote start systems you have to do this... ( I do not want a remote start to clarify)... Or is there an easy way to bypass this?
Old Jun 30, 2009 | 10:32 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah saw this on a JDM civic YOOOOO....
Eirulisse
Aug 15, 2015 12:34 PM
poppinparker
Aug 10, 2015 09:20 AM
dbarber
Jul 25, 2015 01:34 PM
stickmantijuana
Jul 19, 2015 10:33 AM
