RX8 Wire Colors & Locations
Old Jun 28, 2009 | 04:51 AM
tksnobords's Avatar
TK
PLEASE TEST THE WIRE'S...OR BAD STUFF HAPPENS. DON'T ASSUME THE INFORMATION IS PERFECT. ITS NOT WORTH DAMAGING YOUR CAR.
TEST, TEST, TEST
If you have anything to add, PM me.
12 Volt (+) 12ga. White/Red in driver’s door harness at driver’s kick panel or 12ga Orange just above kick panel
Ignition 1 18ga. Black/Yellow at driver’s kick panel (will be in same harness as door trigger)
Accessory 1 12ga. Green/Yellow (R.A.P.) in driver’s door harness at driver’s kick panel
Starter 18ga. White/Blue left of steering column in small White connector
Horn 18ga. Green/Orange (-) left of steering column in large White connector
Lights (+) 18ga. Red/Yellow left of steering column in large White connector
Lights (-) 18ga. Orange (flashes hazards) at flasher under left side of dash above trunk release button
Door 1 18ga. Black/Blue (-) at driver’s kick panel
Interior Lights Same as door trigger
Trunk/Hatch 18ga. Brown (-) at passenger’s kick panel
Hood Pin 18ga. Violet/White (-) (N.C. use relay) above driver’s kick panel in smaller group of wires that lead into main harness going through firewall
Trunk Release 18ga. Yellow (-) at trunk release button on bottom left side of dash
Lock (switch) 18ga. Lt. Green (-) @ 1000 ohm in driver’s door harness at driver’s kick panel
Unlock (switch) Same wire (-) @ 0 ohm
Disarm (key) 18ga. Green/Red (-) @ 0 ohm in driver’s door harness (extended pulse will unlock all doors)
Arm Input 14ga. Red/Blue (M) in driver’s door harness or at keyless entry module behind passenger’s kick panel
Disarm Input 1 14ga. Red/Black (M) at same
Disarm Input 2 14ga. Green (M) at passenger’s kick panel in door harness or at keyless entry module
Old Jun 28, 2009 | 04:31 PM
tksnobords's Avatar
TK
12v and Ignition Wires
Attached Thumbnails RX8 Wire Colors & Locations-dscf1894-2.jpg   RX8 Wire Colors & Locations-dscf1900-2.jpg   RX8 Wire Colors & Locations-dscf1897-2.jpg
Old Jun 28, 2009 | 04:36 PM
Motomouse's Avatar
thanks for your replay !!
the 2nd and 3rd pics are showing the ignition wire black with yellow correct??
Thank you
Old Jun 28, 2009 | 04:41 PM
tksnobords's Avatar
TK
Yeah the Ignition is Black/Yellow
Old Dec 2, 2009 | 12:54 PM
FarSide792's Avatar
Choo Choo!
What does R.A.P. mean? And this is only powered on with the ignition, correct?
Old Dec 6, 2009 | 03:08 PM
tksnobords's Avatar
TK
the accessory wire comes on before the ignition wire....when you turn the key to accessory. make sure you test the wire before using it...!!!
Old May 30, 2017 | 08:59 PM
RN-RX8's Avatar
Where does the hazard switch wire connect?
I bought my RX-8 and noticed the hazard switch didn't work. I went to install an aftermarket stereo and noticed the hazard switch wasn't even plugged in to anything. I looked around and could not find the other end that should attach the hazard light switch...HELP ME PLEASE!
Old May 30, 2017 | 09:07 PM
StealthTL's Avatar
Electrical diagrams.pdf
Old May 31, 2017 | 12:17 AM
RN-RX8's Avatar
I found out that the hazard button plugs into the stereo receiver motherboard. I have a dash kit that will route the button properly. Thanks for the wire diagram anyway
Old May 31, 2017 | 02:10 PM
tksnobords's Avatar
TK
glad you found it. Can you post some pictures.
Old May 31, 2017 | 07:13 PM
limitlesscodes's Avatar
Can anyone provide me with the audio channel wire colors on an 04 GT w/ bose. Specifically the colors as they go into the Bose amp, or if anyone knows how to check which are which with a multimeter.
Old Jun 1, 2017 | 12:02 AM
StealthTL's Avatar
Originally Posted by limitlesscodes
Can anyone provide me with the audio channel wire colors..........
The colors are all in the diagram above.
....also in the first post of this thread - dude, do you even Audio?
Old Jun 1, 2017 | 01:36 AM
Found it pg. 86/88. Guess I should've looked harder. After some testing I've now verified that the picture of the Bose headunit harness with wire colors on the sticky is correct for my car. Thanks
Old Jun 1, 2017 | 01:43 AM
I suppose for verification I could set my multimeter to AC and probe on the expected audio channel pins of the harness while playing left channel right channel stuff to see what is "left channel/right channel" and what is +/-. Though if the colors match up perfectky when I go to splice in then I'll be confident enough to just do it.
Old Oct 31, 2018 | 01:09 PM
shaundurnan's Avatar
UK unknown wires connect to the cigar lighter
Hello All,
Whilst trying in vane to swap out my SAS module behind the Radio, I discovered some wires without connectors.
I have remove the ashtray, centre console etc. and disconnected cigar lighter, bulb etc.
There are 2 wires, sheathed, which went back into the dash, connected to the cigar lighter connector.
The 12v has an inline fuse, (same style fuses as main fuse box)
seems to be supply to something
Hadn't noticed it until I pulled the cable to one side and the wire came out.
They have bare ends, like I may have snagged them at some point against a sharp edge and cut them.
not that I remember being the rough.
Although I did get frustrated about not being able to get to the SAS module connectors.
Can anyone tell me where they go ?
Help !!! :-(
Shaun
Old Sep 15, 2019 | 10:10 PM
JDos's Avatar
Fuel Pump Relay... Power?
I am trying to locate the correct wiring harness under my steering wheel that encompasses the power for my fuel pump. I would like to splice in a kill switch to the lead that comes from the computer after power has been given to turn the pump on. Having the switch off will prevent the wrong people from being able to start my car. This has been a frustrating process because I cannot hold the harnesses when I turn my key (to find it by feel when the pump primes) as I also must depress my clutch to start and the location of the housings would require me to have 3 hands. I know where the the fuel pump relay is in my engine bay and also the fuse that supplies it. My issue is finding the correct harness. If I can find that I can find my lead with my multi metre. Thanks all ! ( I have been reading through threads and believe there is a possibility it is under the driver rear seat? But I believe that is the pump location itself as it is right beside my gas tank vs the actual harness?)
Old May 31, 2020 | 04:49 PM
Gyro_Bot's Avatar
Zoom Zoom
Emergency wire. Orange. Correct location?
I am looking to hook up my after market alarm. All is done except the blinking light function. There is an orange wire found just behind and above the trunk release. I’ve tapped into this wire (as your chart indicated) however the result is I still get no illumination from the after market alarm.
I have a photo of the wire I tried to tap into.
is this the correct orange wire to connect to for left and right blinker activation? Or... perhaps I should be connecting to the actual left and right side blinker wires (bright green... but no idea where they are under here).
Just FYI I’m installing the MoboKey alarm system. Everything else is working great! Nice unit
Old May 31, 2020 | 06:46 PM
StealthTL's Avatar
The orange wire flashes the indicators when grounded, in theory.
However it runs to the keyless entry module which is just black magic.
Post #8, connector F1-01.
The actual indicators are the green/white and green/black, in this same connector.
Old Jul 25, 2021 | 01:27 AM
Tamhay's Avatar
Hi all i have the interior lights disconnected was like that when i got the car i have the wiring loom for it with 3 plugs 1 for front interior lights 1 for the middle/ rear interior lights then a bigger one which I assume plugs into the car wiring loom but i cannot find out where it goes?
juiceRx8
Dec 4, 2018 05:09 PM
olyrx7
Jul 5, 2018 09:54 AM
SBZRO
Sep 13, 2007 08:53 AM
NeoJay
May 15, 2006 02:23 AM
B-Nez
Jan 8, 2003 01:01 AM
