Oil FilterMag Really Works!!
Old Jun 25, 2009 | 03:42 PM
ASH8's Avatar
Super Moderator
AU Oil FilterMag Really Works!!
Did a service and Changed oil and filter.
Here are the results of the Filtermag after being on for only 1690 KMS!!!..
Very happy when you consider the 09's have a factory internal sump magnet.
the Filtermag catches the oil 'metal' as it circulates.
Thoroughly recommend this product.
Attached Thumbnails Oil FilterMag Really Works!!-oil%2520filter%2520rx-8%5B1%5D.jpg   Oil FilterMag Really Works!!-oil%2520filter%5B1%5D.jpg
Old Jun 25, 2009 | 03:44 PM
ASH8's Avatar
Super Moderator
Also..
Because of a "shipping" stuff up...too long to explain...I have a double order of SS250 Filtermagnets.
So I have 2 available to anyone who wants one....Boxed and brand new only $AU55.00ea delivered (in Australia ONLY).
You can see what it looks like in the pic.^^^
PM me if you want one.
Series 1 RX-8's have NO magnet installed by Mazda.
VERY easy to install, about 1 second!
Old Jun 25, 2009 | 03:45 PM
Brettus's Avatar
Boosted Kiwi
does it just clip on to any filter or does it come with the filter ?
Old Jun 25, 2009 | 03:52 PM
ASH8's Avatar
Super Moderator
The size is for any "small" oil filter...
Just happens to fit the 8 perfectly.
It is held on by it's strong magnets on the outside of the filter.
You can see it (SS250) if you look hard enough...
YES they are reusable and will last a lifetime..
When I wiped the inside of the oil filter all the Metal Particles were as fine as toothpaste!!...black toothpaste!..
The strong magnets picks up metal smaller than 25 microns which your oil filter can not catch.
So, you have engine oil that will stay cleaner and your oil filter...a very good investment that will fit on ANY new Mazda.
Old Jun 25, 2009 | 11:05 PM
Kusanagi's Avatar
Hi Ash, I'll buy that extra off you, PMed you
Cheers,
K
Old Jun 25, 2009 | 11:11 PM
Good info.
Old Jun 25, 2009 | 11:57 PM
ASH8's Avatar
Super Moderator
Cheers,
K
SORRY MATE, THEY ALL SOLD OUT ON THE OTHER SITE...
I had to Honor an inquiry Earlier than yours, I will let you know if the sale falls through....
Please at this stage disregard the PM I sent You...
Ash
Old Jun 25, 2009 | 11:58 PM
ASH8's Avatar
Super Moderator
The two I had for sale have .....
SOLD OUT....
Available from..
www.filtermag.com
Old Aug 3, 2009 | 11:00 PM
ASH8's Avatar
Super Moderator
Just DO IT!!
I just wanted to inform ALL RX-8 owners that IMO this is a critical MOD or ADD on which will help to save your engine and keep your engine OIL from circulating minute metal particles around your engine below 25 microns...your Oil Filter CAN NOT Catch these.
Considering the Series I RX-8's 04-08 have NO factory installed Sump Magnet like the FC RX-7, and Mazda have re-introduced this same sump magnet in the 09 RX-8's....I would ask...WHY????
Old Aug 10, 2009 | 06:30 AM
matt13b's Avatar
Ash, I'm sold on this magnet and just tried to order it. When I type in the car model details it suggests 2 magnets. A small or a large. Would I be better off with the large as it is a stronger magnet? The one you recommend is the smaller one.
The other question is, does it matter where they are placed on the oil filter?
Old Aug 10, 2009 | 09:03 AM
alnielsen's Avatar
The answer is out there.
The recommended ones appear to be the same size. It's just one is stronger than the other.
http://shopfiltermag.com/cart/ymm.ph...el=RX-8+R2+1.3
Old Aug 10, 2009 | 05:05 PM
ASH8's Avatar
Super Moderator
/\ WRONG.....
They look similar sizes but the HP250 is THICKER and WILL NOT FIT ON an 09~ RX-8.
Where the SS250 will Just fit.
Should not be a problem with Series I 04-08 RX-8 for either size..
The HP is a Stronger Magnet that you pay more.
Location Matt?, supposed to be away from the heat side of the engine.
Old Aug 10, 2009 | 08:01 PM
matt13b's Avatar
Thanks mate.
Old Oct 26, 2013 | 12:41 AM
ASH8's Avatar
Super Moderator
worth a bump?
Old Oct 26, 2013 | 12:42 AM
Brettus's Avatar
Boosted Kiwi
that's what she said
Old Oct 26, 2013 | 09:06 AM
paimon.soror's Avatar
I will cut into my filter at the end of this OCI, but at the fraction of the price this just might make more sense:
Corvette Engine Filter Oil Pan Magnet Cheap Protection | eBay
The filtermag has a 75lb pull, while this has a 65lb pull. We will see how it fares. I installed this during my last oil change.
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
akagc
Aug 11, 2015 07:07 PM
RotaryRider
Jul 20, 2015 07:05 AM
