Prototype RX8 Found
Old Mar 27, 2002 | 12:03 PM
veloceracing's Avatar
Moderatin this biznatch
Prototype RX8 Found
Magazine X (in Japan) has a scoop on a prototype RX-8 that has been riping up the roads in Europe. The car is disguised in typical auto industry garb, borrowing a front bumper from a JSpec RX-7, rear from the Mazda Japanese Cappella. The following is what they have to say about the prototype...
We have finally caught the new model which will likely become the new RX-8.
When the scoop photos were brought to our editorial office, all the staff gathered to identify the model. However, it was not the RX-8 displayed at the Tokyo Motor Show in October 2001.
Then one of the staff pointed out that he had seen the front bumper before somewhere and another staff brought the catalogue of the RX-7. Yes, it was it. It was the bumper fitted on the RX-7. There are hollows in the area where the position light and turn signal should be located, indicating that the details of the prototype has not been finalized yet.
Also the headlight is not that of the RX-8, Attenza nor Cappella as turn signal has been situated at the inner part of the headlight.
Side view is also strange. There are lines on the front fender, front door and rear door. But the lines on the front and rear door are uneven, showing that the rear door is brought from the RX-8 but the front door is something new. Not many Mazda cars use grip type door handle and the one on this car has different shape and size from others. Still there is a possibility that the under part of the front door is derived from another car and the upper part is original.
Rear view of the car is also a surprise. Squared combination light and a bumper with black braid are derived from the current Cappella.
Twin tail pipes have been projected from holes which seem temporary. The Attenza has twin pipes but are situated more closely together so the test car has nothing to do with the Attenza.
Looking at the rear pillar, what looked like a window has been identified as a trace of body panel joint. Do they want to obtain a big trunk capacity by adopting as large overhung as that of Cappella? Or did they want to camouflage the test car by using the tail part of the Cappella?
As you can see, its shape is not definite yet. However, we are confident that the rotary sports car will continue to exist in the 21st century. It is likely that the new RX-8 will be introduced in early 2003.
http://www.rotarynews.com/view.php3?...=20020327.html
Old Mar 27, 2002 | 12:23 PM
YC-6's Avatar
Everyone knows what the car will look like pretty much. I don't see why they bother with the camo.
Old Mar 28, 2002 | 01:06 AM
renesis.ca's Avatar
nah i don't think so
I truly believe that what we have seen, from all the magazines, mazda web sites and so forth that the RX-8 will look very very identical to the images being displayed.
Maybe what is being disguised is a RX-7 protptype, or maybe even a new Porsche 944 model.
Spy car scoops with blurred images become exagerated media stories. So extreamly exagerated that they qualify for British tabloid paper coverage. :D
Old Mar 29, 2002 | 10:50 PM
YC-6's Avatar
It could also just be a test mule to check the engine's durability.
Old Mar 30, 2002 | 09:38 AM
yukikaze's Avatar
Lightbulb
For the first time, a message is put in.
Did you read the May 2002 issue of Magazine X(in Japan)?
Although the scoop photograph of RX-8 had appeared (in Europe), it was just like that of the model of Tokyo Motor Show.
The different part was equipped with the side marker.
Is this message an irrelevant utterance?
SUKIEE
Oct 9, 2017 09:41 PM
SayDfuse
Nov 21, 2015 02:35 PM
D13
Aug 22, 2015 11:42 PM
MolecularConcept
Aug 5, 2015 04:43 PM
