Clutch bracket problems
Old Jun 17, 2009 | 08:07 PM
szym0n's Avatar
Well my clutch bracket broke on me monday, bought a new one w/ fluid sports bracket put it together but the problem now is that the screw that held my clutch bracket the first time it had broken is half and I had a stud and couldnt remove it...
So I drilled a new hole next to the broken stud and put a new screw to replace it but now, everytime i press the pedal in the bracket bends because the one screw is not enough...
So I drilled another hole about 2mm toward the engine but the metal is way to thin and does not give any support to the first screw..
I know this will not last long and will cause problems..
What can I do??
My friend suggested to weld the bracket to the frame...Good idea??
Ill post pix up of my problems soon.
Old Jun 17, 2009 | 08:23 PM
Huh? You broke one of the studs on the clutch master cylinder?
Old Jun 17, 2009 | 09:29 PM
szym0n's Avatar
no i broke the screw on the top part of the bracket.
Old Jun 17, 2009 | 09:31 PM
post the pictures....
Old Jun 17, 2009 | 11:47 PM
Jon316G's Avatar
Grasshopper
My first thought was to just use a tap to the rear of the broken bolt and secure the top of the pedal with a bolt and washer.
But the body/metal thickness might not be enough to secure it well.
I too want to see pics of this
Old Jun 20, 2009 | 02:11 AM
szym0n's Avatar
Heres some pix of my problem.
Old Jun 20, 2009 | 08:48 AM
dude, DIG IT OUT, dont just freaking drill another hole
I see a fail right there.
Old Jun 20, 2009 | 10:53 PM
szym0n's Avatar
how?? what would u do?? i tried to drill it again...I trying to use the extractor tool, and tried a punch...What else can i do??
And yes it id gonna fail soon cuz it bends when i depress it allthe wway down.
xAgyex
Jun 3, 2026 03:47 PM
Warrior777
Jun 24, 2019 04:47 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
RenzoRx-8
Aug 25, 2015 10:29 PM
thewatcher101
Aug 4, 2015 10:42 AM
