Radiator Light
Old Jun 17, 2009 | 11:29 AM
meskism's Avatar
FL Radiator Light
Hey folks!!! I am having my radiator light come on and off. It stays on for approx 5 seconds and just turns off. Its been doing this for at least a week. I look at the temp gague and temp seems to be normal. Any ideas??? Should I take it in the the dealership even if light is intermittent???
Old Jun 17, 2009 | 11:32 AM
never fear, Jedi is here!
Unfortunately this is a common problem with some RX-8's.
The first thing I would suggest you do is check the coolant level. I'm sure it's probably fine but better to rule out the obvious up front.
2nd: if the coolant is fine, then you most likely have a sensor malfunction with the coolant overflow tank. Some people have been able to temporarily fix it by trying to clean the sensor but most end up either disconnecting the sensor or just replacing the tank.
Mazmart has a thread with new OEM tanks for sale. (I believe they're updated so this shouldn't happen)
As for your temperature gauge: dont' rely on it too much as the needle will not move past its normal spot until your coolant temps are already above 220°F. If you ever do see it move, know that your car is already overheating.
Im_DANomite's Avatar
I love GOOOLD
check the coolant level and top it off.
Old Jun 17, 2009 | 11:34 AM
Search is your friend but here you go. I just posted a link to this yesterday.
https://www.rx8club.com/showthread.p...ant+light+dash
Old Jun 17, 2009 | 04:38 PM
ken-x8's Avatar
As common as the bad sensor problem may be, when my radiator light went on the coolant was indeed low. Topped it off and it's been fine ever since.
Ken
Old Jun 17, 2009 | 04:57 PM
Shijin-Kun's Avatar
Rotary Power!
I had this problem, problem went away when mazda replaced my radiator and reservoir.
Old Jun 17, 2009 | 06:00 PM
04RX8man's Avatar
Rotary Powered Countryboy
JEDI IS HERE! check coolant if it's good prob the sensor!
Old Jun 18, 2009 | 06:20 AM
meskism's Avatar
Talking
Thank Jedi and all....Ill do just that!!!!
05rx8mazda
Nov 28, 2015 09:42 AM
Vedivan1
Sep 18, 2015 12:39 PM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
