Which lightweight battery?
Old Jun 14, 2009 | 04:07 PM
bse50's Avatar
Well, after 4 years my battery is starting to work improperly so i thought that it would be a good idea to replace it with a light weight one considering that i seldom use the car's audio system and lights. I also track my car often enough to justify the small sacrificies that this kind of battery needs you to do.
The problem is, which one to buy?
I don't need a no-weight battery, i would like it to be less than 22pounds or so and capable of starting the car after a week of absolutely no use.
Any suggestions? I know that Braille makes this kind of battery but any other quality product is welcome. A model number would be even further appreciated
Thank you!
Old Jun 14, 2009 | 05:43 PM
04RX8man's Avatar
Rotary Powered Countryboy
I say go with Braille prob the lightest that u will find.....but I don't have the cash for that so i stick with DieHard ahah...but that s not at all lightweightt
Old Jun 15, 2009 | 03:19 PM
bse50's Avatar
Yep, i would like to receive a little help about the model too
It should keep the charge for at least 7-10 days.
Thank you anyway!
Old Jun 15, 2009 | 08:05 PM
Psychofox's Avatar
我愛台妹,台妹愛我
try odyssey pc680
Old Jun 16, 2009 | 01:55 AM
bse50's Avatar
You made my day, it is sold in italy!
17amp\hr though... must have a look at their whole range
Old Jun 16, 2009 | 02:45 AM
TrochoidMagic's Avatar
is adjusting valve lash
^^if u want something for street use reliability, try odyssey pc925mjt. 25lbs, modify new b+ terminal wires and tap the stock tie downs to sit the battery lower. and punch holes on the side covers for the tie down protrusions...
just a recommendation...
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Oct 1, 2015 09:11 AM
Evan Gray
Sep 26, 2015 12:30 PM
