Dealership changed cat=exhaust sounds way different?(examples inside)
Old Jun 12, 2009 | 09:30 PM
bryanl's Avatar
My cat was bad(glowing), and they ended up replacing it without much hassle. The car has a tanabe exhaust. It sounds much different then it used to.
Here is the way it did sound(not my car) at idle
http://www.youtube.com/watch?v=37xdBuurGDs
This is that tanabe revving
http://www.youtube.com/watch?v=DO_nLcWHbwI
Now here is how it sounds(my car)
http://www.youtube.com/watch?v=AV9SwkV7Tgc
Any reasoning for this? In need of some help here, thanks.
Old Jun 13, 2009 | 12:12 AM
if you had a glowing cat, that means its clogged.
now you got a "good" cat, flowing like it should, of course it will sound different.
Old Jun 13, 2009 | 12:23 AM
bryanl's Avatar
A non clogged cat shouldn't make the exhaust sound like **** the way it does now--it sounds like a busted civic with a fart cannon. Was there a part change on the catalytic converter that mazda previously used to the ones they are using now? I'm at a loss as of why the tone has changed so dramatically.
Old Jun 13, 2009 | 12:49 AM
tanabe exhaust sound like that (normally)
you probably never heard another one in person before you got yours did ya ?
unless you have an exhaust leak somewhere, which I doubt. but it could happen.
Old Jun 13, 2009 | 03:04 AM
if the cat came apart it could end up trapped in the rear exhaust
Audio Concepts ATL
Sep 26, 2021 01:59 PM
SupraG
Sep 21, 2015 12:09 AM
akagc
Aug 11, 2015 07:07 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
