Weekend Install Problems
Old Jun 8, 2009 | 09:21 AM
Leshil's Avatar
Needs More Rotors
I installed some new stuff this past weekend which I thought went okay, but after I installed the Esmiril ignition upgrade, new spark plugs, new ignition coil wires and AEM CAI, I seem to get really bad gas millage and I get a popping during acceleration. Any ideas?
Old Jun 8, 2009 | 10:27 AM
Grungepup's Avatar
Oilfield trash
when i did my MS CAI install, i dropped about 2mpg ..... as far as the popping no idea
Old Jun 8, 2009 | 10:55 AM
dillsrotary's Avatar
jersey fresh
any more details? most of the time it maybe a small flaw somewhere in your install, did you verify and double check everything accordingly?
Old Jun 8, 2009 | 11:03 AM
alienRX8's Avatar
Boosted!!!
bad gas mileage and popping sounds like you are now running rich, double check you installs that you didnt leave any vaccum hoses off and double check all the connection on the ignition
Old Jun 8, 2009 | 11:09 AM
05rx8mazda's Avatar
B.I.G
check the coils first... as for the intake it will have no power on acceleration.. usually around 5k rpms.. popping sound is more to do witht he ingiton or the plugs. double check the wires and the plugs making sure you didnt switch them up.. happened to me once lol
Old Jun 8, 2009 | 11:06 PM
Front and rear trailing plugs are swapped or the coil wires.
check those items too.
Old Jun 9, 2009 | 02:18 AM
Flashwing's Avatar
3-wheeler
The Esmiril ignition upgrade normally requires splicing of your harness to get it hooked up. If this was done you may want to check your wiring to ensure there's no issues.
I agree that you could be operating with a non-firing coil that would cause incomplete combustion.
Old Jun 9, 2009 | 08:54 AM
PSTNLSS's Avatar
The Former PSNTLSS
Shoulda went with the BHR ignition=] I don't have it but I heard good things!
Old Jun 9, 2009 | 06:21 PM
Leshil's Avatar
Needs More Rotors
It seems to have been an issue with the spark plugs themselves. Bought stock ones and my problems stopped. Also, I have the BHR harness for the ignition coils so I didn't have to deal with the splicing.
xAgyex
Jun 3, 2026 03:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
steve11711
Aug 22, 2015 11:11 AM
Belalnabi
Jul 17, 2015 07:48 PM
