Catback Install - Cat bolt problem
Old May 29, 2009 | 07:51 PM
rubberduckie's Avatar
I can't get those damn 2 bolts to move. I tried cleaning them and some liquid wrench, and still nothing. I have an 07 with 8100km, so not a lot of miles. Is it possible with the heat that the threads have melted? I am not too experienced with car repair, but this doesn't seem too difficult. Any tips/tricks for getting these things to move or should I just take it too a muffler shop for the install?
Old May 29, 2009 | 08:00 PM
heyarnold69's Avatar
Rotary wanabee
use a torch for like 4 secs... move easily
Old May 29, 2009 | 08:02 PM
expo1's Avatar
He's as bad as Can
How long did you let the liquid wrench set? also which part are you trying to loosen? I need to DBL check but I think the nuts you remove are the ones facing the rear. What you wish to remove is the nut that goes on the left of this stud, which I think points to the rear. There is a nut on the other end but that is welded to the pipe and will not come off. That is what the right part of the stud screws into.
Old May 29, 2009 | 09:32 PM
Ya, I am trying to move the rear facing nut. I let the liquid wrench set for 20-30 min. I am going to give it another go tomorrow I think, so it will have had a week to set in.
Old May 29, 2009 | 10:29 PM
Jon316G's Avatar
Grasshopper
Heating it will help.
You can also use a breaker bar to loosen it.
And you should be loosening the nut holding the spring compressed.
xAgyex
Jun 3, 2026 03:47 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
ableobject
Mar 22, 2016 11:37 PM
Espo
Aug 11, 2015 07:11 PM
dbarber
Jul 25, 2015 01:34 PM
