Starter? Battery?
Old May 26, 2009 | 08:25 PM
Rx8_rotory_Noobie's Avatar
RotorHeads Unite!
Unhappy Starter? Battery?
Need help: When i go to start my 8 it cranks and cranks and cranks and then FINALLY starts up, turns over prolly 5-6 times before starting. JW if this is a habitual thing for rx8s to do, maybe something im overlooking.
Casanova
Old May 26, 2009 | 08:29 PM
Spinning Sushi's Avatar
I <3 Sushi
Is your 8 an 04?
The 04's comes with a weak starter.
There is a TSB for the starter.
Old May 26, 2009 | 08:34 PM
m3pkrobert's Avatar
exactly the same problem I had a few days ago, starter fixed the problem GL
Old May 26, 2009 | 09:08 PM
Colorcode's Avatar
i get the same problem. whats a TSB??
Old May 26, 2009 | 09:26 PM
RotorHeads Unite!
anyone know where i can get a good cheap starter that will last?
Old May 26, 2009 | 09:27 PM
Jon316G's Avatar
Grasshopper
TSB = Technical Service Bulletin
You can view them here:
http://www.finishlineperformance.com....php?pageid=11
Old May 26, 2009 | 10:28 PM
rx8cited's Avatar
Discounted Mazda OEM parts - most likely much cheaper than your local stealership.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Quiggs321
Sep 30, 2015 05:34 PM
