Throw out or input bearing ???
Old May 17, 2009 | 08:41 PM
eddieinc1's Avatar
I've searched, found posts and problems but no real answers.
I have a loud whining noise when i let the clutch out. It didn't have it when i first got the car. And seems like its gotten louder and worse now. Doesn't seem to have any real problems other than the noise. I have about 44k miles on it. It had 10k when i got it.
Any sugestions? or experiences?
I went to dealership and they charged me for a transmission fluid change and then said it didn't fix it and it would be around 350-400$ to change the bearing, that ..that is what they believe it is......
2006 rx8
Old May 17, 2009 | 08:53 PM
Winning 8's Avatar
Hot Pit
throw out bearing, may as well change the flywheel and the clutch.
Old May 18, 2009 | 09:34 PM
eddieinc1's Avatar
eeh... what kind of price should i be expecting??
If i'm not mistaken..it should be under warranty untill 45k right?
Old May 18, 2009 | 09:52 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Whirring with the clutch out is the throwout as mentioned, but I will say that this throwout is pretty noisy even when new. I have had two now and they all make noise. I say this as you may not have a failure, just noise. Someone with experinence should take a listen before you swap them.
The bearing is cheap. Like $25 bucks or something. Not worth even remembering.
In any case, this can be done on jackstands. Otherwise, you are going to be paying hundreds for what might not even be a problem.
JCTaylor
Sep 30, 2015 07:31 PM
Luke.s
Sep 30, 2015 05:57 PM
alming1132
Sep 30, 2015 11:30 AM
Learners_Permit
Sep 27, 2015 07:38 PM
