Few mods going in, waiting for dyno readings.
Old May 6, 2009 | 09:21 PM
tofu_box's Avatar
Thumbs up Few mods going in(Dyno Chart Updated)
Hey all
Went to Promaz today to get a few bits and pieces installed
Basically im getting
-racing beat, CAI + Duct. (Upgrade from K&N pod inside stock intake)
-Agency Power Under driven Crank Pulley
- Microtec LT-10 Piggyback ecu + dyno tuned.
I dunno what to expect from it all.
So therefore i asked to take a pre mod dyno and after mod dyno for a comparison.
Once i get it all done i'll post the dynos here so people can get a basic idea, about power increases.
also getting in it a basic service aswell.
P.S (dont laugh at my kw)
Ok its all done
I tried to keep conditions as much as possible during the dynos so i get a fair comparison.
Before:
Mods:
Promaz ignition
magnaflow exhaust system
K&N drop in inside OEM airbox
After;
Same Mods
RB Intake + Duct
Agency Power Pulley
Microtek Lt-10 dyno tuned
roughly about 14rwkw increase.
The Dyno should explain itself
(its a bit rough cous simon ran outta ink for printer, however i'll get a better one towards end of week)
Anyhow afterwords
I had Decarbon, Yellowtop Battery, Service done.
Original Battery had one failed cell inside (both dyno ran on original battery)
hope this gives everyone a idea.
there has being a drop in lower end power however mid-top i can really feel it. More response also from top end, normal revving feels smoother, slight drop in sound system volume at a full stop, not really noticeable. R
other then that, its hard to say i've been driving a v8 5litre around... so yea cant really give a proper opinion (feels like a power drop lol)
Also note, this only had the first run, there was a few more kws squeezed out after more tuning, but the blue line didnt show (ran outta ink) so i'll need to get it
so since my dyno before this date, was 90.4
can i assume i am now OVER 100 rwkw? lol
*quote*
with all these mods you should crack the 100rwkw mark for sure
for comparison.
His dyno gets stock autos at 60 kw, and mauel at around 93 kw
Old May 6, 2009 | 09:46 PM
Tim Tam's Avatar
This should be interesting!
Old May 6, 2009 | 11:01 PM
Revolver's Avatar
Shootin' from the hip
Excellent.
Many people have trod down the same path without doing this, so hopefully you'll be able to confirm or deny the oft stated 'seat of the pants dyno' impressions with some hard data.
Thanks for sharing...
Old May 6, 2009 | 11:18 PM
Brettus's Avatar
Boosted Kiwi
should be good for 15 whp mostly from the tune
pity you didn't search before getting the LT10 though .....
Old May 7, 2009 | 02:13 AM
Revolver's Avatar
You're forgetting the louder induction sound - known to have a significant effect on 'seat of pants dyno' - "it's louder! It must be faster..."
Old May 7, 2009 | 03:49 AM
tofu_box's Avatar
well i just couldnt find the lack of support for other ecu tuning devices down here in melb. There is Cobb which really does appeal to me the fact you have to drive base map and wait for someone to send the tunes over (this is my everyday car) therefore i have some chills at the idea. Another is the ProTuner, which i cant really find anyone here either to do the tuning.
Lt-10 was provided by Promaz, so full support, and i am considering going their turbo kit. which means with the LT-10 the turbo kit would cut out the cost of the ecu.
Old May 7, 2009 | 07:30 AM
DrGonzo's Avatar
Did you consider their Bosch coil kit? I had the upgrade done last week and the bum dyno reckons it's picked up a little more power but more importantly it feels smoother and revs more cleanly, especially in the mid range.
Old May 7, 2009 | 09:14 AM
tofu_box's Avatar
its already done.
and the hi-flow cat from there aswell.
Old May 7, 2009 | 07:06 PM
Tim Tam's Avatar
Wow, with all these mods you should crack the 100rwkw mark for sure..............(sorry, cheap shot at your auto).
I was wondering though, is it wise to up the power with the auto gearbox? Mazda reduced the power because the auto couldn't handle it, right? (what year model is your RX?)
Old May 8, 2009 | 03:27 AM
tofu_box's Avatar
cheap shot indeed.
Better then the US side of things, i prob would have being flamed and blown up for having an auto no matter my circumstances lol.
Its a 03 Auto, the gear box can easily hold the increase, (to be honest i dont expect alot) butter maybe not an turbo. From my knowledge the limiter was there to be *safe* and 9k revs is a big difference to 7.5k, and 9k being the limit, and sometimes the tran will lag for abit when tip-tronicing. My guess, was the 1.5k rev being the *safer* options then to push it to the limit.
Now that is my opinion in terms of reasons for lower rpms, of course it is partially informed from reading on forums, most likely there are a 100 other reasons and i need to go find a flame suit.
Anyways the gear box holding up, was from my mechanics, although the did suggest a gearbox strengthen for a turbo.
Anyhow, pre these mod i got a 90.4 rwkw from a dyno, however keep in mind my car was not prepared for it. (friend dragged me along last minute)
So oil was fairly black *7k kms driving* oil filter prob needed change, K&N airfilter has not being cleaned for about 40k kms.. (lazy i am)
And some sought of exhaust issue, (issue being left seems to run more rich then right?) wtf? getting that checked out atm.
Oh yea and a ton of clothes in boot, (last minute cleaning) lol.
So it was not really a day to see peak performance of car.
I dynoed it to about 7k.
Every ran it showed a drop around 5.5-6ish range, of about 4-5rwkw? then started to climb again.
Cant exactly remeber as Promaz has that dyno sheet. So getting that issue checked out.
Dunno if it was normal or not? maybe someone has some insight.
But yes, the before and after, would be from the same dyno, but different times. So hopefully i can provide some guidelines for true power increases in some hard facts.
However there could be a few assumptions made aswell, such as butt dyno, for things like response, which i will post up later.
Anyways tuesday it should be ready.
Old May 10, 2009 | 05:51 PM
Revolver's Avatar
Look fwd to seeing the results...maybe put all the clothes back in! ;-)
Old May 13, 2009 | 05:00 AM
tofu_box's Avatar
Bump for update!
Old May 13, 2009 | 06:04 AM
rotarenvy's Avatar
dam it's a low reading dyno. but the difference is what matters and how it feels.
and auto isn't a great starting point. you should think about forced induction.
Old May 13, 2009 | 10:01 AM
tofu_box's Avatar
well it feels great, limited driving as im sick. but i def feel the power + in high ranges, 4.5k rev+ lower i feel the drop.
FI ey, who drives a rx8 and dont want one of those :P
Old May 13, 2009 | 05:43 PM
Tim Tam's Avatar
Tofu,
You can't claim more than 100kw until you have written proof!
Old May 13, 2009 | 08:58 PM
tofu_box's Avatar
damn i still failed
Old May 14, 2009 | 12:54 AM
auzoom's Avatar
Hmmmmmm.........
Jas' There is a mob in Preston that we all use as reference and in comparison Simons reads roughly 8 - 12 Kw lower. DAMN close mate.
I am hoping that with the new premises, Simon will get an RPM input for his Dyno
Old May 14, 2009 | 02:16 AM
tofu_box's Avatar
arggggg...... so close....... mmmmm.... octane booster, sound system out, take out rear seat, errrr........ borrow friend's light rims..
am i over 100 rwkw yet?
Old May 14, 2009 | 05:56 AM
auzoom's Avatar
Hmmmmmm.........
sorry dude, weight doesnt help on the dyno. The rims might
Old May 14, 2009 | 05:58 AM
tofu_box's Avatar
lend me yours andrew
Old May 14, 2009 | 06:21 AM
auzoom's Avatar
Hmmmmmm.........
I could, but they have semi's on them and that would send you the wrong way.
Old May 14, 2009 | 06:51 AM
tofu_box's Avatar
not after im done with em
speaking of which andrew, your car all sweet now?
Old May 14, 2009 | 02:39 PM
auzoom's Avatar
Hmmmmmm.........
lol. Spare Engine is being machined, lightened, balanced and ported. Waiting on the ransom note from Mazda for the seal kit and the ceramic apex seals. Car is still going for the time being though
Old May 14, 2009 | 05:03 PM
tofu_box's Avatar
lol @ ransom note.
Sounds good, you aiming at pushing up your psi aswell?
Old May 14, 2009 | 08:55 PM
Revolver's Avatar
Spare huh? Got every confidence in your turbo conversion then?
Or are you just looking to maximise the power available?
