upgrade injectors with greddy turbo
Old May 4, 2009 | 09:43 PM
rv_rx8's Avatar
I have a greddy turbo kit installed but want to boost more psi (9 or 10 psi) im gonna buy bigger injectors but i talked to an RC injector specialist and said that instead of getting 4 550cc i can get 2 750 cc and put one of the 750cc closes to the port so it can shoot direct fuel to one of the rotary then set up the other 750 cc the same way with the other rotar. the other two stock injectors should even up with the 750cc that distributes fuel to each rotar. It is cheaper and seems like a good idea because it is receiving the same cc total to each rotar. but Idk if its risky.What do you guys think?
Old May 4, 2009 | 10:12 PM
blackenedwings's Avatar
Life begins @ 30 psi
....What?
Old May 4, 2009 | 10:20 PM
636's Avatar
636
Rice Police
^ what he said. Lol i like how he said "ro-tar" Reminds me of one of my friends that said it like...roooowww--taaaar >>.
Old May 4, 2009 | 10:22 PM
Brettus's Avatar
Boosted Kiwi
get 2 blue injectors from an AT rx8 and stick them in the P2 positions ...
Old May 4, 2009 | 10:32 PM
MazdaManiac's Avatar
And then an engine management system that can control them.
Old May 4, 2009 | 10:50 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I got two matched 780cc injectors for you if you are interested.
Old May 4, 2009 | 11:07 PM
rv_rx8's Avatar
sorry i typed it in a hurry i edited to explain better.
Old May 4, 2009 | 11:09 PM
Brettus's Avatar
Boosted Kiwi
sorry - makes even less sense now
Old May 4, 2009 | 11:12 PM
Brettus's Avatar
Boosted Kiwi
I would direct you to the thread that explains the injector layout but some unsociable person removed the pictures LOL
Old May 4, 2009 | 11:14 PM
rv_rx8's Avatar
lol. thats what he said and i called a rotary specialized and said that it would work. thats y i was jw.
Old May 4, 2009 | 11:20 PM
Brettus's Avatar
Boosted Kiwi
https://www.rx8club.com/showthread.p...light=injector
that thread did have all the info you would need but not anymore - have a read anyway - if you want a good laugh .
Seriously - just fit the blue injectors like i said - you will get away with doing that without changing your engine management (i have done this) because they are only 20% bigger than stock . The larger injectors will definately need management so that is an extra cost .....
What management are you using ?
Old May 4, 2009 | 11:25 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
This what you were looking for? The links are just broken. Hardly sure that is an unsociable act.
Attached Thumbnails upgrade injectors with greddy turbo-injector-position.jpg
Old May 4, 2009 | 11:27 PM
rv_rx8's Avatar
oh i see. but i got emanage ultimate.
Old May 4, 2009 | 11:28 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
P1 is the bank of two. Secondaries are the inner most injectors of the bank of four and P2 are on the outside.
Now if someone could tell me how to differentiate the wires for the two secondaries from the colors on the wires, I would be greatly appretiative.
Old May 4, 2009 | 11:33 PM
Brettus's Avatar
Boosted Kiwi
ah - you have the emangle urinate . Not good .......
Old May 4, 2009 | 11:35 PM
rv_rx8's Avatar
thanks gives a better picture of the injectors now.
Old May 4, 2009 | 11:40 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
They are buried under the UIM. The UIM is not difficult to remove the SECOND time you remove it. The first time is somewhat longer. I highly recommend leaving the two bolts/nuts holding the UIM to the Oil filler alone and taking them off as a unit. That saved me hours right there.
Dont touch the p1s unless you absolutely have to. Bank two is much easier to access.
To be honest, I still have no idea what you are trying to do, but if you get ahold of an int-x I seriously do have two 780cc injectors that I need to get rid of.
Old May 5, 2009 | 12:04 AM
rv_rx8's Avatar
ohh now i understand wat your saying.thanks.
no im not trying to remove my p1 injectors. but that was an option that the RC specialist gave me but i wasnt too sure wat he was talking about. yeah im trying to but pretty expensive.lol
but thanks for the injector offer but im gonna have it running how i have it for now until i get money .
rv_rx8's Avatar
oh really dang. y is that.
Old May 5, 2009 | 05:32 AM
Wow. That is some seriously bad advice.
Why would you say something so misleading?
Old May 5, 2009 | 08:09 AM
Because Emanage is horrible and will probably result in you blowing your engine.
Old May 5, 2009 | 01:36 PM
I wouldn't go that far. The E-Manage can go quite a long way.
Its just not really up to the task of handling the elevated power levels that almost everyone goes for as soon as the GReddy kit is fitted to their car.
Old May 5, 2009 | 01:48 PM
Mr.&Mrs.Magic's Avatar
so what is the next suggestion for injectors if i choose something other than AT blues(these are good to about what hp?) for FI above 350hp. The cheaper the better I was looking yesterday and it seemed most places wanted +$200 for a set but there were a few at a fraction of the cost why?
Old May 5, 2009 | 02:59 PM
PhantomRX-8's Avatar
Bad Ass
Are the blue injectors enough for the BNR upgraded turbo or should I just go with 650s? There isnt much info with the BNR turbo yet so Im not sure which to go for. Im only looking to be around 310-320whp. BNR said their turbo should be able to flow enough for 360whp so 320 should be easily obtainable. I just dont want to go to big on injectors cause then they get hard to dial in.
Old May 5, 2009 | 05:50 PM
Big injectors are easy to dial in with the AccessPORT.
I run 850cc in my P2s.
