Damn foglights!
Old Dec 25, 2003 | 01:35 PM
Genom's Avatar
Not so Super right now
Damn foglights!
OK. Have some time today to finally change thes puppy's out. Now I got the bottom plastic panel off and can reach the plug just fine. I can see it start to turn and it gets maybe 1/3 of the way and STOPs. I mean STOPS. I just spent 45 minutes trying to twist them off and I cant get them to budge either way more than a few milimeters.
Both sides do the same thing. ic an see the 3 flanges in front that need to move to get it out but they will not budge beyond a very small radius. Is there something I am missing?
Thanks.
Old Dec 26, 2003 | 12:27 PM
kristopher_d's Avatar
Drive Master
You probably need to press them in, then turn. Haven't looked at mine, but that's usually the problem when a bulb wont budge.
Old Dec 26, 2003 | 02:07 PM
Omicron's Avatar
Yeah, that's what I was going to suggest.
Old Dec 27, 2003 | 09:19 PM
syntrix's Avatar
I like cheese!
Yeah, push in a bit.
Also they will only turn one way and come out. As they get closer to the point of release, they get harder to turn.
Old Dec 28, 2003 | 07:37 AM
Genom's Avatar
I'll give it another go and try pushing a bit. I thought I tried that as well, but maybe I didnt push hard enough.
Old Dec 28, 2003 | 02:53 PM
T666APH's Avatar
If you look in through the lens you can see the key-way, easiest way in up through the lower plastic couple off screws easy!
SimonT182
Oct 2, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
RotisserieEngine
Sep 26, 2015 12:57 PM
HMSS013
Aug 28, 2015 03:02 PM
tigg.z
Aug 26, 2015 09:51 PM
