Questions about TEIN basics
Old Apr 22, 2009 | 04:46 PM
Shijin-Kun's Avatar
Rotary Power!
So im thinking of getting the TEIN Basic coilovers. I dont want to get too much of a drop. Ive had bad experience with low suspension before and i dont want to go through it again. I dont want to bottom out and scrap the bottom of my car, i dont want to waste my tires. Ive read good reviews on the tein basics that they give good handling for good buck. I mostly want a somewhat comfy ride because i do nothing but street driving. My car wont see any track time. So my question is how much of a drop does tein basics drop over stock and will it bottom cause problems for regular street driving?
Old Apr 22, 2009 | 08:56 PM
imput1234's Avatar
I ♥ Drifting!!!
PM Swoope he is selling one NEW for an unbelievable price.
Old Apr 22, 2009 | 09:02 PM
Shijin-Kun's Avatar
Rotary Power!
Dont have the money right now, just getting some info on them. Pretty much window shopping.
Old Apr 23, 2009 | 03:17 AM
coilovers allow you to adjust the height to what ever you want.. that is kinda the point.
ride is subjective. the teins are firmer than stock..
you might check out the tein website it will answer all of your questions.
beer
Old Apr 23, 2009 | 08:02 AM
michaelsk8er's Avatar
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/spring-rates-other-basic-suspension-info-79096/
First post has the drop rates and more suspension info after it.
Old Apr 23, 2009 | 08:48 AM
Shijin-Kun's Avatar
Rotary Power!
Ok i see that the minimun ride height for the front is -1.34 inches and the back -.16. If i set the suspension drop to this much will it cause any tire rubbing issues or will i have to get it aligned properly? Sorry im a total noob when it comes to suspension.
Old Apr 23, 2009 | 08:56 AM
08boostedmzda's Avatar
I'm not sure about rubbing with that drop but you will have to get the car aligned after putting the coilovers on.
Old Apr 23, 2009 | 08:59 AM
Shijin-Kun's Avatar
Rotary Power!
could i take it to a regular place like firestone or would have to take it to a specialist in modified suspension?
Old Apr 23, 2009 | 09:19 AM
J03K1LLARX8's Avatar
ジョーイ
do not get the basic set up, really sh*ty ride. save up a little more and get the TEIN FLEX or the MONO FLEX. cant go wrong. the ride hight is perfect and the ride is really smooth not cazy bumpy.
Old Apr 23, 2009 | 09:26 AM
myriadshalaks's Avatar
rot8ing
^not true.
Old Apr 23, 2009 | 01:08 PM
Sifu's Avatar
Opulence
In Houston there is a shop called Southwest alignment. A couple of my friends go there for their alignment and they are really good with lowered cars.
Old Apr 23, 2009 | 01:20 PM
Shijin-Kun's Avatar
Rotary Power!
thanks for the tip sifu.
Old Apr 23, 2009 | 01:41 PM
Peppy@kacework's Avatar
Hoarder of RPF1's
Skip the Tein Basics. To hit the cheap coilover price point Tein really skimps on the build quality and in 99% of their applications they will ride much worse than stock with no performance benefit. Hell, I'd run Megan coilovers(junk) before I'd run the Tein Basics. No offense to anyone that has the Basics, but in all the cars I've been in with them they were crap. Any of the more popular spring/shock combinations will ride and perform better.
Old Apr 23, 2009 | 02:49 PM
rot8ing
i dunno, man. maybe they were set up bad. i put mine on, dropped them as low as is safely possible, got an alignment, and they ride great.
they're sure stiffer than stock, but they eliminate that nasty body role that comes from the factory.
the roads here in florida are a lot like runways; they're not asphalt. But the teins handle the bumps and what not very well, i think.
if i wanted to be more competitive at the track, i would want something more, but it's hard to beat a good, issue free, drop and no body role for 700 bucks.
Old Apr 23, 2009 | 05:50 PM
JantzenRX-8's Avatar
^^^ I'm with you. I don't have enough experience with other suspension set-ups to say what's better but my Tein Basics handle great on the street and in autocross.
They're definitely stiffer than stock in terms of ride comfort but it's not too overbearing unless you're on some really crappy roads.
As for ride height, i have them almost to the bottom setting with no rubbing and i'm running 9.5" RPF1's with 255/40/18's. When i first got my wheels they rubbed a bit on the back left but i had the car aligned and i haven't had an issue since.
I'd recommend them. A good strut and spring combo is a good option too.
Happy window shopping.
Old Apr 27, 2009 | 11:08 PM
coolstorm92's Avatar
I agree with several of the above comments. The ride quality with the basics is crap. I switched to tein s-tech springs with MS shocks and its great for what I am looking for. If you need a more performance oriented setup, I would definitely recommend spending a little more for the flex.
gwailo
May 14, 2024 06:57 AM
LB2739
Jul 9, 2019 02:25 AM
yapakanichi
20
Sep 10, 2015 07:17 AM
tgaffner
Sep 7, 2015 08:49 PM
Tsurugi
Sep 7, 2015 08:27 PM
