How to remove 3M automotive double-side tape?
Old Apr 22, 2009 | 12:14 AM
krijpipudht's Avatar
Hi guys! My name is Tony.
From: San Francisco Bay Area 94542, USA. Earth. Solar System. Milky Way
I taped voltage stabilizer to the battery cover. Now I would like to relocate it.
I used hard force to pulled it out from the battery cover.
But all tape still remain on the voltage stabilizer.
I tried everything that I could think off.
Alcohol
Paint Thinner
Acetone
WD-40
Sea Foam Spray
Windex
Googone (left it overnight!)
It still not pealing off. Not at all....
What next?
Thanks.
ps. 3M double-side tape really does the job.
It withstand high heat in engine compartment very well.
Just hope that you do not want to move it in the future.
Old Apr 22, 2009 | 12:27 AM
tubingchamp's Avatar
What mawd bug?
Damn, have you tried heatgun+string?
Old Apr 22, 2009 | 12:45 AM
kersh4w's Avatar
Hit & Run Magnet
goo gone + rubbing
Old Apr 22, 2009 | 12:48 AM
that is correct for the square! i would go with dental floss.
Old Apr 22, 2009 | 12:55 AM
Thanks, same way of de-badging?
I'll try.
Originally Posted by kersh4w
goo gone + rubbing
Thanks for input.
Yep, I did.
Does not work.
Old Apr 22, 2009 | 12:57 AM
kersh4w's Avatar
Hit & Run Magnet
must be different stuff, goo-gone plus tons of rubbing worked for me.
Old Apr 22, 2009 | 10:13 PM
Go to speality Auto store buy the 3M adhesive remover.
Yes, they do make this product.
Other wise... brake cleaner works on most surfaces including some plastic and cloth.
Edit: MEK Methol Ethel Ktone if you can get it.
Old Apr 23, 2009 | 02:09 AM
I'll try.
the other stuff will get the goo off after you remove the part, and that is the hard part.
yurcivicsux
192
Sep 12, 2017 10:54 PM
Atreyu
34
Jul 6, 2010 04:29 PM
elysium19
Series I Do It Yourself Forum
May 5, 2009 07:34 PM
Olorin2
Apr 27, 2006 08:24 PM
l008com
Jul 30, 2004 06:42 AM
