No spark or when trying to start.
Old Apr 15, 2009 | 07:16 PM
RAYRAY04's Avatar
OH No spark or when trying to start.
OK, here's a new twist. After replacing the oil lines from the oil cooler with new stock oil lines, the car will not start. I have no spark at the coils or plugs. So I put a new Battery in, 4 new coils Pulgs, plugwires, a new starter, and changed the oil too. The car turns over faster now, but still has no spark. It has always been a hard to start car.
The reason for changing the oil lines was because they were very rusted and leaking. When I realized the car would not start after replacing the lines, I was told to replace the wires, plugs, and coil. The starter needed to be replaced...it was the original. This is a 2004 Mazda RX8 with 54,000k miles.
Is there anything else that I could look at before taking it into the shop? Any help would be greatly appreciated.
Old Apr 15, 2009 | 07:18 PM
RAYRAY04's Avatar
OH No spark when trying to start.
Old Apr 15, 2009 | 08:17 PM
Cam's Avatar
Cam
this space for rent
did it start before working on the oil lines?
If it did maybe you loosened or disconnected a ground wire? I dont have a shop manual or wiring diagram in front of me. double check engine bay for loose or unconnected connectors, etc.
Old Apr 15, 2009 | 08:18 PM
teknics's Avatar
Certified Mazda Tech
check connector near crank/eccentric shaft position sensor, check connection and wiring all are right in the oil line area of the motor.
this would cause the motor to crank without spark or fuel.
kevin.
Old Apr 15, 2009 | 08:49 PM
^ Good call.....most likely the ESS....
Old Apr 15, 2009 | 09:05 PM
rx8cited's Avatar
Fuses?
Old Apr 15, 2009 | 09:47 PM
PSTNLSS's Avatar
The Former PSNTLSS
I'd suggest checking the fuse and all wires and connections.
But with all the money you put in already, I would have run to the shop by now
RAYRAY04's Avatar
The car was running before I changed these parts.
Kevin, Im not sure where the crank/eccentirc shaft position sensor is.
There is a sensor right below the oil filter with one line green wire on it but is tight.
I checked for loose ground wires too.
Old Apr 15, 2009 | 09:55 PM
ESS is on the drivers side of the front cover...looks like a silver cylinder lined up with the trigger wheel behind the ES pulley
Check the wiring...if the connector got hit...it could break easily
Old Apr 15, 2009 | 09:58 PM
RAYRAY04's Avatar
fuse check out fine. however. the dealer wanted $1000.00 to change out the oil lines.
$100.00 for oil change.
$800.00 for the tune up.
and $600.00 for the starter.
I did it all for less then $500.
Old Apr 15, 2009 | 10:09 PM
RAYRAY04's Avatar
dannobre,
Are you referring to the front cover as the hood of the engine? Is there a diagram or picture that I could visualize as a reference? This is my daughters car in the city and I live in the country any visual tool that I can take in town with me is very helpful. I am not sure what the trigger wheel behind the ES pulley is. You have been very helpful....this is my first time working with a rotary engine.
Old Apr 15, 2009 | 10:20 PM
RX7145's Avatar
rayray04 Sent you a email.
-Paul
Old Apr 15, 2009 | 10:26 PM
teknics's Avatar
yea like he said. If you look head on to the crank pulley and picture it as a clock face it's at like 5, 4 o'clock.
kevin.
Old Apr 15, 2009 | 10:28 PM
RAYRAY04's Avatar
Should the tach bounce (move) when cranking or trying to start the engine. Mine does not move at all while cranking.
Look down below the idler pulley under the A/C compressor belt
It is down there.....
If the sensor isn't working...you will get no Tach signal
Old Apr 15, 2009 | 10:29 PM
teknics's Avatar
car has no rpm signal>? check what were telling you....
kevin.
Old Apr 15, 2009 | 10:34 PM
RAYRAY04's Avatar
OK, I now know what sensor you are talking about, It is like a magnet. When working with the tools they would get pulled over towards it an stick.
However, before installing all the covers we did spray it off with a mild cleaner and wiped it off really good. However, I did not notice any broken lines. I will double check this tomorrow.
thanks for all your help, I really do appreciate it.
Old Apr 15, 2009 | 10:41 PM
Pretty sure the tach moves with normal cranking....that is a dead give away there is no ESS signal
Old Apr 15, 2009 | 11:37 PM
teknics's Avatar
yea I never checked with it disconnected but with it connected it will move, i know that. Never bothered to look with it unplugged before, ill be sure to check during the next decarb, seriously ill probably do one tomorrow.
kevin.
Old Apr 16, 2009 | 09:13 AM
hall sensor or its harness on the trigger wheel is damaged or you just need to reset the e-shaft profile.
Old Apr 16, 2009 | 09:17 AM
oh hahah there are were 2 threads. now merged
Old Apr 16, 2009 | 09:28 AM
here
Attached Thumbnails No spark or when trying to start.-mazdarx805_engine2.jpg
Old Apr 16, 2009 | 11:54 AM
teknics's Avatar
Originally Posted by zoom44
here
cant believe they left that sensor hanging out there, the front cover redesign need is obvious especially in that pic.
and yea the 2 threads had me confused too, i knew i posted then it wasnt there..
kevin.
Old Apr 16, 2009 | 06:21 PM
RAYRAY04's Avatar
I would like to thank everyone who chimed in with their knowledge. It was very helpful.
The problem was that the wireing got cut when I was tighting down the idle pully. The screw went into the wire and cut both sides. So, now I know when cranking the engine over the tack does bounce when starting the car. I drove the car 50 miles today. I still have some issues after a long drive the car did stahl, it started back up after several attempts to start and letting it sit for three minutes. If I go to work (5 miles) and turn the car off, or to the store, the car will start immediately. We have had this problem before with the car stahling before at stop signs or stop lights. The care idles at 1000 rpms. With the AC on the rpms drop to 750 rpms and pulls on the engine. Is this normal?
I was told that if I took my car to a Mazda dealer that they should update the flash or have it reflashed to the newest settings at no charge or cost to me. Is this true?
thank you!
Old Apr 17, 2009 | 07:36 AM
RX7145's Avatar
Glad you got it running.
