Minor noise when idling
Old Apr 14, 2009 | 02:53 PM
djcode's Avatar
Unhappy Minor noise when idling
Hey guys... I am a new user to these forums. I have found a lot of the information very useful so I am glad to have joined the community.
I have a very minor noise that happens when the car is idling. If I press down on the clutch ever so slightly the noise will go away. I am not a mechanic by any means, but it leads me to believe something with the clutch causing the noise.
The clutch isn't bad and it drives great... this is the only problem that I have noticed since buying it at 58k miles.
Thanks in advance!
Old Apr 14, 2009 | 04:51 PM
djcode's Avatar
after a little digging I found this thread, this seems to be the same issue: https://www.rx8club.com/series-i-trouble-shooting-95/clutch-noise-when-idling-goes-away-when-clutch-pedal-pressed-101087/
Old Apr 14, 2009 | 07:01 PM
teknics's Avatar
Certified Mazda Tech
yea mazda calls it "gear rollover noise" i think they released a TSB as well noting it as normal.
kevin.
Old Apr 14, 2009 | 08:29 PM
yep gear roll over noise.
TRANMISSION GEAR ROLL-OVER NOISE
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 ZZZZZZZZ
Some customers may complain of a whirring noise from the transmission while at idle N in neutral. The noise may also be described as a light rattling when the AC compressor cycles on. This noise is normal N no repairs should be made. Confirm the gear rollover noise by depressing the clutch pedal, the noise should be eliminated. Compare noise to another vehicle to verify this is a normal characteristic. 1. No repairs should be attempted on vehicles with gear rollover noise.
Old Apr 14, 2009 | 08:34 PM
several reasons why you can hear it
1. Aisin's are a little louder than other manual trannies but you can hear it from other trannies.
2. You are sitting much closer to the tranny than you would be in most cars
3. The idle rotary is really quiet
good read
http://books.google.com/books?id=ca8...-yfb2V1xnT-ca0
Old Apr 14, 2009 | 09:40 PM
teknics's Avatar
good info, +1.
kevin.
Old Apr 14, 2009 | 09:43 PM
warren(silver-roxy-8)'s Avatar
no sleep til it spools
i think the noise sounds cool....especially the way sound goes away when you push in the clutch...sounds like a super awesome machine of some sort.
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Danield97
Sep 30, 2015 05:59 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
