Suspension Question
Old Apr 12, 2009 | 12:56 AM
M-ster's Avatar
Suspension Question
Hi guys,
My suspension seems to be losing its function especially the rear. I can see that the car is sitting very very low when the rear are filled with 2 passengers. And when i go over bump, the rear wheels are hitting the upper inside wall of the wheel well.
My questions, it this instance, is it a shock issue or is it the spring? I'm hoping that i could just change the problem parts as suppose to be swapping out everything. Advise.
Old Apr 12, 2009 | 02:25 AM
DOMINION's Avatar
I don't buy Kool-Aid
Sounds like you need new shocks and springs. Also check out your rear sway bar end links. Mine bent and my car was ridding low and dirty.
Old Apr 20, 2009 | 08:49 PM
Mugo's Avatar
Originally Posted by M-ster
Hi guys,
1. Shocks out. or
2. Spring seats dislocated.
If shocks, you should be able to tell that your ride is bouncy. If its the spring seats, the rear just sounds harsh on uneven surfaces, with lotsa knocking sounds.
Shocks replacement is a must if they're out.
Spring seats replacement is inexpensive.
Old Apr 20, 2009 | 08:56 PM
M-ster's Avatar
Hi Mugo,
Thanks very much for the informative reply.
Sounds like its the spring seat dislocated as the way you've described.
Will get it checked. At least I've a slight clue when i talk to the mechanics now.
Thanks a bunch!
Brokegang
Jan 3, 2016 12:45 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
