Fumoto Valves
Old Dec 21, 2003 | 06:45 PM
syntrix's Avatar
I like cheese!
Which Fumoto drain valve for RX8?
Anyone know the correct fomoto p/n for the RX8?
http://www.fumotovalve.com/
Someone posted some info after this post:
https://www.rx8club.com/showthread.p...threadid=17117
Old Dec 22, 2003 | 06:15 PM
classicred's Avatar
Fumoto Valve
If you are not familiar with this device, it is a very nice brass valve that replaces your oil drain plug. It is a well made ball type of valve with positive action that you open and close with your fingers - no tools needed. It makes oil changes easier, and you don't even get hot oil all over your hand or have to fish the plug and washer out of the old oil. The decision to replace the washer or not each oil change is moot.
I ordered the correct F106 model and also the same one for my Miata. The Miata needs the ADP106 extension to clear the pan. It turns out that the extension is also required for the RX-8. There is no listing for the RX-8 yet.
A good source is www.lubespecialist.com .
Bob
Old Dec 22, 2003 | 11:34 PM
syntrix's Avatar
I like cheese!
Heh, guess we were thinking along the same lines. I posted this before this post:
https://www.rx8club.com/showthread.p...threadid=17045
Old Dec 23, 2003 | 09:48 PM
syntrix's Avatar
I like cheese!
Just picked one up using this:
http://forums.nasioc.com/forums/show.../t-454573.html
Through the end of the year for 15% off.
Discount code: SVC5
Website is: http://www.fumotovalve.com/
:D
Old Jan 1, 2004 | 03:55 AM
i3man's Avatar
I decided to order one too. I was too late for the discount code though. What kind of washer does this require?
Old Jan 1, 2004 | 01:04 PM
syntrix's Avatar
I like cheese!
Comes with all you need. Looks like you do need the extension.
Mine arrived in lik 2 business days. I was rather surprised
Old Jan 1, 2004 | 03:12 PM
i3man's Avatar
I read what classicred said and ordered w/ the extension. I haven't changed my own oil since I had my RX-7 which is 15 years ago :p
Old Jan 1, 2004 | 03:24 PM
syntrix's Avatar
I like cheese!
DOH! That's a long time!
Worst part about the fumoto... after you install it, you can't use it until your NEXT oil change. I guess that's not a bad thing though
Old Jan 1, 2004 | 07:06 PM
Speed Racer's Avatar
Certified track junky!!!
I placed an order for a Fumotovalve too and have also been thinking about adding Speed Bleeders to make bleeding the brakes a one person job. Now I just need to figure out what size will fit.
Old Jan 1, 2004 | 08:23 PM
syntrix's Avatar
I like cheese!
Email them at speedbleeder@earthlink.net and ask what fizzle fits the shizzle.
Old Jan 1, 2004 | 08:34 PM
I e-mailed them before the holidays and never received a response. I figured that I would try again next week when the holiday bustle is over.
Old Jan 1, 2004 | 08:59 PM
syntrix's Avatar
I like cheese!
I emailed them and got a response about an hour later:
The size(s) that you need for your application is as follows:
Front.....SB8100
Rear......SB7100
When ordering Speed Bleeder consider ordering the Bleeder Bag and Bleeder Hose Combo.
The Bleeder Bag resembles an IV bag that is used in hospitals and the hose is silicone tubing that is specifically
sized to fit our Speed Bleeders. It is flexible, won't fall off while bleeding and is unaffected by brake fluid.
The Bleeder Bag and Hose Combo prevents an unnecessary mess. Both are reusable.
The Combo is priced at $6.00 and is a great value.
Speed Bleeders can be ordered at https://www.speedbleeder.com/order.htm
Thanks for your interest in Speed Bleeder.
Michael Sulwer
I'm going to start a new thread about this.
edit: SPEED BLEEDER THREAD
Old Jan 1, 2004 | 09:07 PM
Thanks for the info. I just placed an order and we'll see how it goes.
Old Jan 1, 2004 | 09:29 PM
syntrix's Avatar
I like cheese!
these guys have had good stuff for us veteran sport bike owners, I'm sure it will go very well on the RX8. I might order in a few weeks, as it's good to flush the brake fluid every year or two
Old Jan 2, 2004 | 04:22 PM
i3man's Avatar
Syntrix -
Did you put the valve in yet? I'm not sure if this a problem on the 8 but the threads seem to extend past the bottom of the oil pan on some cars, did you find this to be a problem?
I was thinking of getting my Dremel and drilling 2 small holes or cutting a small "V" to let the all the oil drain if the threads do extend beyond the bottom of the pan.
I saw a pic of what someone else did for another car on a link on one of the other threads.
Old Jan 2, 2004 | 05:32 PM
syntrix's Avatar
I like cheese!
Haven't installed it yet. Probably at least 2 weeks away, but I almost got a wild hair and installed it last night.
Old Jan 2, 2004 | 05:44 PM
i3man's Avatar
I'm planning to install the 1st weekend I get it. I've got 600 miles now and want to change oil before 1000 miles.
Old Feb 26, 2004 | 09:25 PM
Knerk's Avatar
Limecat De'Original!
Did any of you guys install your valves yet?
Old Feb 26, 2004 | 09:39 PM
syntrix's Avatar
I like cheese!
Not yet, but I think I'm due for an oil change this weekend.
Old Feb 27, 2004 | 12:06 PM
Knerk's Avatar
Very cool - I shoud get mine in a few days - I will change my oil 150 miles early just to get it over with.
Old Feb 27, 2004 | 12:28 PM
I tried installing mine but I found that it wouldn't fit. The top of the valve is about 1/8" too tall and it hits as you try to screw it in. It is so close to fitting that it is a bit frustrating that I had to revert back to the normal drain plug. Hopefully everyone else will have better luck.
Old Feb 27, 2004 | 12:49 PM
Knerk's Avatar
did you get the adapter w/ it ?
Old Feb 27, 2004 | 12:58 PM
No, that might explain why it doesn't fit.
Old Feb 27, 2004 | 01:17 PM
Knerk's Avatar
I looked at the plug before I ordered. It looked kinda tight so I got the adapter - figured I would return it if I didnt need it. I guess I will need it
Old Mar 22, 2004 | 12:09 PM
Knerk's Avatar
Well I put it on yesterday- fits like a glove- pretty cool little gizmo .- Ill try and post some picks in a few days
