flooding
Old Apr 9, 2009 | 03:19 AM
neilryan54's Avatar
flooding
i recently had difficulty starting my rx8 after i started it in cold weather and turned it off before it had chance to warm up, my brother in law had the same trouble with his rx8 and said it started easily with a tow . : any views:?
Old Apr 9, 2009 | 07:24 AM
Huey52's Avatar
Registered Zoom Zoomer
You had difficulty but it started, or it did not start?
Do you have the old starter (pre- circa Jan '05 manufacture)?
Yes, if you have a manual transmission, push/pull starting it is a viable option.
Old Apr 9, 2009 | 05:05 PM
neilryan54's Avatar
yes it started but only after nearly 2 hours of crankin on and off which soon flattened the battery, had to start with a direct super charge ( which didnt do any good for the starter motor ). its a pain havin to warm the engine every time i need to move the car off the drive but hey! its worth it.
Old Apr 9, 2009 | 06:05 PM
Kaiser bun's Avatar
Yeah Sioux Sioux!!!
Its not that hard to let it warm up, i drive a block and a half to school in the middle of winter (-20 degrees so no way in hell i am walking) all you have to do is start it 5 min before u are going anywhere.
Old Apr 9, 2009 | 07:07 PM
kersh4w's Avatar
Hit & Run Magnet
Old Apr 10, 2009 | 01:06 AM
Kaiser bun's Avatar
Yeah Sioux Sioux!!!
Originally Posted by kersh4w
lol lemme see u walk to school when you get frostbite after about one minute.
Old Apr 11, 2009 | 11:03 AM
newguy's Avatar
zoom fuckin zoom
i would suggest keeping a quick jump in the trunk. my wife stalled and flooded mine a while back then she killed the battery trying to perform the accel to the floor crank 10 sec/ 3times fix w/no luck. After I got home I jumped it w/ her car and it didnt start after 30 sec of cranking so I went ahead and spun it for 60 sec in 10 sec intervals then it started but I dont know if you would get 60 sec of cranking on its own battery so Im buying a porta-jumper.
Old Apr 11, 2009 | 11:15 AM
Ryoma-kun's Avatar
Get the upgraded starter hopefully under warranty. It'll fix the flooding and hard start issue.
Old Apr 11, 2009 | 06:24 PM
neilryan54's Avatar
its not the starter that gives up its the battery , what happens is that when the engine is flooded the fuel washes away the oil in the chamber which acts as a seal for compression , without compression the engine will never start. if you let the dealers fix it all they do is remove the plugs , squirt oil into the s/plug openings which acts as a seal, they then relace plugs and hey presto it starts and you end up with a large bill. neil ryan 54. u.k.
Old Apr 11, 2009 | 06:33 PM
neilryan54's Avatar
hey! ryoma kun nice motor, why dont you put your no plate under the grill like i did. it looks cool ?.
Old Apr 11, 2009 | 06:56 PM
shazy's Avatar
You are the ***** for not walking in -30 degrees!
92trbolzr
May 18, 2025 09:04 AM
DylanForbes
25
Oct 31, 2017 05:47 PM
fistofmeat
Oct 7, 2016 12:15 PM
Danield97
Oct 10, 2015 05:58 PM
iphil
Sep 21, 2015 10:49 PM
