Any comments on the new Hoosier 255 now that some have tried them
Old 04-12-2009, 09:13 PM
  #51
Row faster, I hear banjos
chiketkd's Avatar
^ How many runs were on these tires Joe?
Old 04-13-2009, 12:13 AM
  #52
No respecter of malarkey
Received 2,009 Likes on 1,638 Posts
Took a close look at mine today. We were close to cording the pair that were on the front for Saturday at El Toro; 24 total runs in the low - mid 40 second range. We swapped them to the rear on Sunday; 12 more runs. I'll be having them flipped soon.
It's odd that the outer front corners are shaving off at a 45 deg angle. The rest of the tire isn't worn much. I've never seen this before, ran other size Hoosier A6s all last year without issue.
Old 04-14-2009, 09:56 PM
  #53
jgoeke's Avatar
As stated before, 20 runs on the corded side, then flipped and now a total of 36 with 24 of these being 40 odd second pro runs.
Old 04-18-2009, 02:47 PM
  #54
SOLO_RX8's Avatar
255's
Chris, Joe or anyone.
Any word from Hoosier yet?
SOLO
Old 04-18-2009, 06:08 PM
  #55
they're waiting on more feedback
Old 04-18-2009, 07:13 PM
  #56
fastmike's Avatar
I need to know what is up with these skins.
We are running them on our BS errr DS car.
FM
Old 04-18-2009, 09:57 PM
  #57
I'm running an event tomorrow, flipped all the tires, will let you know how they look after
Old 04-18-2009, 10:10 PM
  #58
mwood's Avatar
Expect runs in the 60 second range, probably 4 per entry and the opportunity for fun runs...the 'stick doesn't draw as many entries as Oakland.
(now that I've said that, there'll be 300 entries, we'll only get 3 runs and finish at 7 PM...)
Old 05-06-2009, 01:35 PM
  #59
fastmike's Avatar
Who should I call at Hoosier to discuss this issue? The R's in the same size we had seem to be totally ok but the A's....
FM
Old 05-06-2009, 01:46 PM
  #60
chiketkd's Avatar
Harvey has been in touch with Hooiser. Perhaps he could give you a contact name or relay your info onto them?
Old 05-06-2009, 01:59 PM
  #61
Zoom4Three's Avatar
Tim Gilvin & Jeff Speer, Hoosier Racing Tire: Phone 1-574-784-3152
TGilvin@Hoosiertire.com
Old 05-20-2009, 02:39 PM
  #62
chiketkd's Avatar
For anyone who has been in contact with hoosier, any update regarding the 255 tire wear issue?
Old 05-20-2009, 02:48 PM
  #63
SOLO_RX8's Avatar
+1, what he said, any updates?
Time to buy Hoosiers (again). 285's unless something's been fixed on the 255's.
SOLO
Old 05-20-2009, 06:50 PM
  #64
fastmike's Avatar
My email's with Hoosier say that nothing is going to change with the tire.
They regret that not all cars will get good wear with the product.
We were at near 50psi for pressure and are now going into the 50's.
That is on a Cobalt though.
FM
Old 05-20-2009, 08:16 PM
  #65
SOLO_RX8's Avatar
That's too bad, the 255's were the perfect size for our cars.
Guess it's back to 285's and unhappy tire installers.
SOLO
Old 05-20-2009, 08:25 PM
  #66
mwood's Avatar
The 285, or 295 for that matter, is a piece of cake to get on the 8" rim...the Kumho, on the other hand...
Old 05-20-2009, 08:27 PM
  #67
chiketkd's Avatar
FM
Thanks for posting this Mike. Makes the decision on A6 size choice that much easier.
-Chike
Old 05-23-2009, 11:34 PM
  #68
hmm, thought I had posted the info previously
ran low-mid 50s on asphalt and they still rolled over too much, ran high 50s at the Wendover Pro concrete, the problem was not occurring as fast, but it was still going to happen, front grip was fine at that pressure until going over the limit and then the tire was not quick to recover
I won't buy another set of 255s, the 285 Hoosiers mount up pretty easy on 8" wheels, much easier than 245 V710 Kumhos
Old 06-15-2009, 11:05 AM
  #69
chiketkd's Avatar
Can those who have had issues with the 255 A6's post up the manufacturing date from their tires?
Keith Scala will be adding some interesting info to this thread on the 255's he's running on his moton equipped '09 RX-8 sport with only ~-1.3 degrees of front camber.
-Chike
Old 06-15-2009, 12:22 PM
  #70
Zoom4Three's Avatar
Chike -
I don't have the first production run 255's A6's close by to give you an exact date, but they would have 4th quarter 2008 dates.
The 255's John and I tested for this months Grassroots Motorsports article (August 09) were also from this batch. As mentioned earlier in this thread, Hoosier has not planned any immediate changes to the tire.
Although the tire wear appears to be accelerated at the shoulder ply/ tread cap junction point, we (and others-EDJ!) have found the 255's to be very competitive on the clock. On surfaces that are known for high wear rates or drivers who tend to drive through an understeer condition, I would recommend the 285's on the front. The 255 wear rate seems to be much less of an issue on less aggressive surfaces like the Finger Lakes asphalt or our asphalt test track.
John and I have continued to experiment with 285F/255R combo. It has some pluses and minus depending on the course design, but it is another viable option to try.
See you in Toledo -
Chris H
Old 06-15-2009, 01:30 PM
  #71
chiketkd's Avatar
Chris,
Keith had a set at the Finger Lakes NT which had a build date of the 11th week of 2009 which had ~17-18 runs on them by the end of the weekend, which showed no unusual wear whatsoever. What's remarkable is that he runs only 34psi in the front on a car with only ~-1.3 degrees of front camber.
On the Fedex asphalt, one of my local competitors bought a set of 255's earlier this year (has had them for a few months now) and his tires are showing the much described groove of doom forming along the outside edge. He runs -2 degrees of front camber and runs pressures in the mid 40's.
I'm wondering if Hoosier quietly fixed this issue or if there was an issue in the production of the 1st batch of tires.
P.S. Won't make Toledo this year. The DC Pro will be my last national event both Nats. See you in Lincoln!
Old 06-15-2009, 08:17 PM
  #72
Soloseven's Avatar
Here are photos of a front A6 255/35-18 with 17 runs
Photo 1 the shoulder and roll over
Photo 2 All the extra rubber I picked up at the tour
Photo 3 build date
Attached Thumbnails Any comments on the new Hoosier 255 now that some have tried them-img_1437.jpg   Any comments on the new Hoosier 255 now that some have tried them-img_1438.jpg   Any comments on the new Hoosier 255 now that some have tried them-img_1439.jpg
Old 06-15-2009, 08:26 PM
  #73
Soloseven's Avatar
Here are photos of a rear. I used 34 psi in front and 32 psi in rear
Photo 1. less rubber pickup
Photo 2. less rollover
Photo 3. a fun photo
Photo 4. see how the tires sit on a 8" rim, you judge
Attached Thumbnails Any comments on the new Hoosier 255 now that some have tried them-img_1440.jpg   Any comments on the new Hoosier 255 now that some have tried them-img_1441.jpg   Any comments on the new Hoosier 255 now that some have tried them-img_1442.jpg   Any comments on the new Hoosier 255 now that some have tried them-img_1444.jpg
Old 06-16-2009, 08:12 AM
  #74
edj
RX8 Steering Wheel Spacer
edj's Avatar
my 255's have a build date of 0609.
i corded the outside edge after 12 NT runs and 16 PS runs on concrete.
if they did fix the tires it was after mine were built...
Old 06-18-2009, 08:02 AM
  #75
I ran mine with a big front bar and regular pressures this past weekend and the problem seemed to go away, the corners rounded off smooth like normal
IMO the OE or softer bars are allowing too much body roll, think I may have PAXd #1 (not that this means squat )
Quick Reply: Any comments on the new Hoosier 255 now that some have tried them
