Almost DEAD on the QEW
Old Mar 24, 2009 | 04:41 PM
ZmFnZm's Avatar
This could be a continuation of my last thread "Electrical Problem?" however this time it was WAY worse.
Driving in the fast lane on the QEW just before Erin Mills and all of a sudden the F%#king Corolla in front of me slams on the brakes, naturally i do the same, only when i get off the brakes, put her back in gear and try to take off i have NO POWER. She wont go above 3k rpm and the check engine light is flashing.
I manage to make it over to the shoulder without killing myself, shut the car down, and wait a few minutes before i start her back up.
Now the check engine light stays on but at least i can get it past 3000rpm. I limp off the highway, thankfully i was right at the off ramp and now i'm taking the car in to Oakville Mazda tonight so they can figure out what the *#^@ is going on with it.
ARGH
Old Mar 24, 2009 | 05:13 PM
REV-illusions's Avatar
rotary ninja
Sounds like it's gone into limp mode for some reason. Apparently there's a setting in the car somewhere when something goes dramaically wrong that it limits your RPM to 3k so you can get your car to a safe place without distroying the car.
Sorry to hear you're having all these problems dude.
tubingchamp's Avatar
What mawd bug?
Ms cai?
Old Mar 24, 2009 | 05:36 PM
rotarygreg's Avatar
grass hopper
Originally Posted by tubingchamp
Ms cai?
i was waiting for footman to post that. lol.
on the topic of your problem, its only after any sort of really hard braking that you are having an issue right? during these hard braking situations, has your ABS been working? im wondering if you have a couple tires drastically low and your ABS is freaking out with the different sizes and putting you in limp mode. thats a long shot, and im not sure if thats how the computer deals with that but i do remember you mentioning something about a nail in your tire.
Old Mar 24, 2009 | 05:40 PM
ZmFnZm's Avatar
Tires are all fully inflated, and as for the ABS I've been on the brakes hard, but with the tires i have it would need a lot more than that to lose traction. In other words the ABS hasen't gonn off lately.
I have no clue whats causing this, hopefully Oakville Mazda can figure it out, otherwise Al will be getting a call for some help!
Old Mar 24, 2009 | 08:42 PM
qtwre's Avatar
How did you brake? The part where you say you put it back in gear interests me.
Old Mar 24, 2009 | 08:48 PM
ZmFnZm's Avatar
Clutch in, brakes on took it out of gear. When the idiot Corolla in front of me started speeding up again got off the brakes, clutch in, and put her in 3rd (was still doing about 60km/h) and got absolutely nothing from the engine beyond 3k rpm, and even below that it was rough
Old Mar 24, 2009 | 08:49 PM
ZmFnZm's Avatar
Ms cai?
Nope no CAI on my car. I have an HKS intake installed. It sits in the stock position inside the engine bay.
Old Mar 24, 2009 | 08:54 PM
qtwre's Avatar
You didn't happen to notice if it stalled did you? Obviously it shouldn't when in neutral but it may have died and you bumped it back to life when you put it in third? Possibly causing limp mode. Just an idea.
Old Mar 24, 2009 | 09:47 PM
ZmFnZm's Avatar
nope no stall
Old Mar 24, 2009 | 10:15 PM
Footman's Avatar
Dodging those Corollas
MS cai does not have any issues in dry weather conditions in any temperature....
It's only problematic around the 0C mark and it is precipitating.
Old Mar 25, 2009 | 10:33 PM
ZmFnZm's Avatar
And the verdict is....
It turns out that of all things the sensor attached to the gas pedal came loose. How in god's name that happens i don't know but she's as good as new now!!!
Old Mar 26, 2009 | 06:11 AM
rotarygreg's Avatar
grass hopper
that is so crazy that that could cause all that havock. good to know and glad she's all sorted out now. could have been caused by vibration...you know how bad these engines vibrate at ilde. I've seen a few that have rattled the rear brake or signal light bulbs loose enough to fall right out of the socket and it in the bottom of the light housing. on a all three occassions that i've witnessed that (on different cars) the bulb snapped back in perfect so as best as i can figure the bulb just rattled loose.
Old Mar 26, 2009 | 09:55 AM
rotary ninja
heh.. that had happened to my car before I bought it... like the second day of owning it someone said my light was out... took a look.. the bulb was rolling around in the base of the tail light... scratched off a lot of the reflective coating
TeslaMSI
Dec 10, 2015 01:10 AM
Tedd930
Sep 14, 2015 07:18 AM
atmd
Aug 19, 2015 12:43 PM
Eirulisse
Aug 15, 2015 12:34 PM
T_Mags
Jul 24, 2015 11:29 AM
